Pinepower Desktop 120W
Hi all,
I received my pinepower desktop earlier this week, and seems to be working fine when just used for charging devices.
However, when using the pinepower to supply power to a Raspberry Pi 4 (or even to a Lattepanda Alpha) through the type-C port, I'm seeing that the output power just drops then returns randomly, resulting in the SBCs to reboot, and that even multiple times per day.
Initially I thought this was because of me plugging and unplugging the usb cable to charge my pinephone on the quickcharge port, but apparently, after leaving the pinepower desktop on overnight, I figured that the SBCs had rebooted multiple times!
It is strange to see this behaviour, and I would like to know if anyone else is experiencing this issue.
I'm aware the device is promoted as a charger, but I would like to know if this is considered normal.
Thanks!
PS: Feel free to move this message to a different thread if needed, because apparently there is no dedicated forum for the PinePower desktop to this day.
Sounds a bit like PD negotiation not working, do you know what power level the RPi4 is negotiating for?
I think the Pi4 does not have a PD chip so negotiation does not happen. Also, I think there was something about Pi4 having one resistor shared on CC1/CC2 instead of one per line and this made it incompatible with USB-C PD chargers. Boggo standard PSU for Pi4 is probably only/best way to go. Was it ever fixed?
LattePanda Alpha - this seems to have issues with USB-C PD with the PD chip on the Alpha getting confused between being in sink/source modes. No idea if this is related or not but raises a red flag in general. Probably best to use the power brick provided with the Alpha.
This definitely is interesting information, thank you both.
The type-A ports won't provide sufficient power to my Lattepanda Alpha, but I'll try power feeding my Pi4 through one of the regular USB type-A ports.
I'll keep my fingers crossed.
Enjoy your day!
A little update: I'm running my RPi4 with an uptime of 4 days of the first 5V (green) type-A USB port now, so that is good!
(04-22-2021, 04:46 PM)lot378 Wrote: Also, I think there was something about Pi4 having one resistor shared on CC1/CC2 instead of one per line and this made it incompatible with USB-C PD chargers. Boggo standard PSU for Pi4 is probably only/best way to go. Was it ever fixed?
It should be... there was supposed to be a revision within a few months of it being discovered in mid 2019... and we're more than a few months in the future from that! Wink
  Pine Desktop PowerSupply wont power on BSharp 6 8,755 01-07-2025, 08:04 AM
Last Post: skare
  Desktop ready? eiger3970 0 2,067 07-27-2024, 07:49 PM
Last Post: eiger3970
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 3,285 05-03-2024, 12:53 AM
Last Post: Pavlos1
  PinePower 120w On/Off Switch rohtua 7 12,182 08-01-2023, 05:36 PM
Last Post: Callabra
  PinePower USB-C ports dead nbxmike 1 3,881 01-31-2023, 03:45 PM
Last Post: fxc
  Issues with PinePower Desktop superkamiguru 0 2,302 10-24-2022, 07:43 AM
Last Post: superkamiguru
  PinePower 65w - DoA or am I doing it wrong? CampGareth 10 16,910 10-04-2022, 09:02 AM
Last Post: hobbitus
  PinePower 120W Screen Issues t-3 3 5,421 09-26-2022, 05:14 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,769 09-23-2022, 03:47 AM
  PinePower Desktop USB-C port dead qeek 3 5,802 08-29-2022, 12:33 AM
Last Post: gravedigger
