Speakers not working after repair?
Hi
Recently I repaired the screen on my PinePhone and I had some issues with the USB-C board that are now fixed, now the loud speaker isn't working, any ideas?
(03-23-2021, 09:22 AM)ImmyChan Wrote: Hi
It may be unrelated to your other repairs. I say that because my speaker crapped out after about a week of use. Others have had the same problem. But...
Test the phone:
The speaker has the springs that contact the pads on the flexible pcb under it. Get some audio playing (internal speaker selected in settings) and put a multi-meter on those pads.
Test the speaker:
Use a pair of old headphones, cut off one earbud and touch the +/- wires to the springs on the pinephone speaker and see if it produces sound.
(Testing its impedance is probably the right way but IDK enough about that Big Grin )
I ordered a replacement speaker but it has wire leads so I soldered them to the above mentioned pads. It now works great!
I used these: https://www.walmart.com/ip/Unique-Bargai.../171945776
They are a little thicc for the pinephone but they did fit.
I never tested the old speaker because is sucked anyway and I was happy to have a reason to replace it Smile . (I also needed an excuse to buy a pinecil) Big Grin Big Grin
The speaker problem was a win win situation for me. Cool
Good luck!
  FIXED-Newer ver of EC25 Modems, FOSS FW upgr breaks funct- repair FW and IMEI rebuild biketool 4 8,345 10-16-2024, 01:37 AM
  modem not working michelinux 0 2,700 02-16-2023, 04:56 AM
Last Post: michelinux
Question bluetooth speakers and pinephone pro Supervisor 2 4,133 01-30-2023, 09:21 AM
Last Post: Supervisor
  Hardware switch for mic is not working properly submariner 10 17,379 01-25-2022, 07:01 AM
Last Post: wibble
  New vibration motor not working Zebulon Walton 5 11,047 11-13-2021, 03:00 AM
Last Post: kqlnut
  on off power button stopped working dcinoz 3 6,228 09-01-2021, 03:26 AM
Last Post: dcinoz
  LED not working on 3GB variant IVp 2 5,134 08-21-2021, 02:57 PM
Last Post: IVp
Sad PnePhone Braveheart Edition - Microphone NOT Working valentin 15 20,176 08-09-2021, 07:43 PM
  Help needed: Jump drive not working UsnR2 5 10,852 07-09-2021, 03:22 PM
Last Post: UsnR2
  Digitizer not working Zdanb 1 3,996 03-17-2021, 11:45 AM
Last Post: Zdanb
