Observations about SIM card recognition and OS distribution
I got a 3gb Mobian yesterday. While I was trying to get my Google Fi nanoSIM in the white plastic adapter and into the phone, I broke the right-most prong of the SIM card socket. Bummer. I had it for about 15 minutes at that point. Anyway, I went about soldering it back on. It didn't work. I couldn't tell if it was the hardware or software. In flashed Manjaro+Plasma, and the SIM card was not recognized. I flashed postmarketOS latest test distro, and the SIM is good! I can phone and text. So, my solder job is good, the Google Fi is recognized without effort (I use it in an iPhone and Android phone, freely moving the SIM around and it works in everything I've tried).
I installed the latest full pmOS with Plasma, and the SIM is not found. Went back to the test image and SIM is found.
Works:
20210227-0911-postmarketOS-v20.05-phosh-5-pine64-pinephone
Fails:
20210224-0054-postmarketOS-edge-plasma-mobile-3.3-pine64-pinephone-installer
Works:
Manjaro-ARM-plasma-mobile-pinephone-beta2.img.xz
(edit: 2021-2-28)
im having trouble with my sim working also. I managed to get it to work once on manjaro, but I havent seen it working since!
(02-27-2021, 10:12 PM)gibbz Wrote: im having trouble with my sim working also. I managed to get it to work once on manjaro, but I havent seen it working since!
There was an EG-25 update that broke the modem connection a couple days ago in Manjaro Phosh. Switching to the unstable channel fixes it then you can switch back to the stable channel. Plasma on the other hand is a total mess. There are patches to make it work but only temporarily.
I just tried with beta2 of Manjaro Plasma. It's working there. Tried a phone call and that worked fine. Now, to figure out which of these apps is the SMS text one... Confused
Lets see if it works after a reboot? Wink
Working for me. I was surprised when I received a text from someone!
The beta6 of Manjaro Phosh works, so I'm going to declare this resolved.
(02-27-2021, 03:36 PM)lsitongia Wrote: I got a 3gb Mobian yesterday. While I was trying to get my Google Fi nanoSIM in the white plastic adapter and into the phone, I broke the right-most prong of the SIM card socket. Bummer. I had it for about 15 minutes at that point. Anyway, I went about soldering it back on. It didn't work. I couldn't tell if it was the hardware or software. In flashed Manjaro+Plasma, and the SIM card was not recognized. I flashed postmarketOS latest test distro, and the SIM is good! I can phone and text. So, my solder job is good, the Google Fi is recognized without effort (I use it in an iPhone and Android phone, freely moving the SIM around and it works in everything I've tried).
Please create a support ticket and mentioned on your situation. Support team will required you send back the browken mainboard and replacement a new one for you.
(03-03-2021, 12:59 AM)tllim Wrote: Please create a support ticket and mentioned on your situation. Support team will required you send back the browken mainboard and replacement a new one for you.
Thank you. I'm okay for now. My solder job is holding. I'd rather not cost Pine64 more. I'd rather the money go to more of your work than giving me a little repair and end up with my mainboard disposed of.
  install iso from sd card to emmc aular 2 3,981 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,703 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 10,704 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 19,687 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 4,957 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 6,913 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 4,728 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 9,262 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 5,049 02-12-2022, 11:09 AM
Last Post: dekrets
  I just got to find phone in my sd card won't read Tyro 5 10,575 11-15-2021, 01:11 AM
Last Post: alexenwaston
