KDE Plasma Interface Scaling
I have my second pinephone now. It is the KDE Plasma Edition. I quite like the UI and it runs ok it seems. Only problem is, I am missing functionality like scale-to-fit that is available for phosh. I can't for example configure nextcloud client since buttons are missing on the UI. Is there something like scale-to-fit or wlr-randr for KDE Plasma?
Best Regards,
anhilde
(02-27-2021, 10:32 AM)anhilde Wrote: Hi,
Best Regards,
anhilde
Have you tried landscape mode?
Best Regards,
anhilde
Does not help. I have given up for now and returened to arch with phosh. There I get the main things working for a daily driver.
Best Regards,
anhilde
Was there a solution found for this?
Best Regards,
anhilde
I think it shouls work ok. My own nextcloud, owncube, displays all buttons. But of course, I'd like to connect my calendars soon, too. Also my map app, Pure Maps, displays very useable.
If you go to Settings > Display, there's a "Scale" slider. By default, I think it's 200%. You can tweak it.
Try to tweak the font size as well, because Plasma tends to adjust other graphical elements based on font size as well.
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 21,700 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,938 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,135 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,127 03-02-2023, 07:25 PM
  Manjaro plasma-mobile Beta 13 Uturn 13 16,675 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,698 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 16,195 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 3,320 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 53,785 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 2,644 07-04-2022, 11:42 AM
Last Post: tuxmain
