Latest updates
I install latest update and there is login issue, i change PIN to 12 then change kde password to `kde` (via passwd) then i can't unlock the device. Should i reflash? I try ssh but unfortunately it's not enable, root / root refused. Any suggestions?
Have you tried ssh with user `kde` instead of root?
That works, nice. Did you know PIN match password if not how to changed it in command line?
// Edit: Yes PIN matches password Smile
I saw that information for another distro but I was not sure about Manjaro.
Good to know it is the same. I'll stick with numeric a password then, as only numbers can be used to unlock the phone.
(I'm new to PinePhone, just received mine yesterday)
  Latest update Eugo 21 25,490 03-09-2023, 05:27 AM
Last Post: Eugo
  Firefox issue with latest update Barugon 6 8,729 01-28-2023, 01:29 AM
Last Post: alaraajavamma
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 7,204 06-17-2022, 07:48 AM
Last Post: hollerpots
  How to find and remove junk files from failed updates? danimations 4 7,655 10-24-2021, 11:25 PM
Last Post: danimations
Lightbulb Feature request: allow downloading of updates to continue when phone lays idle danimations 0 2,448 09-08-2021, 07:11 PM
  Latest update cured dropped calls when suspended quixote 2 4,808 04-20-2021, 12:31 PM
Last Post: quixote
  Latest dev build of plasma manjaro not booting paju1986 10 16,231 02-26-2021, 10:44 PM
Last Post: lsitongia
