Mobian Issues
One of the biggest issues that I see with the software is that I can not make calls. When I go to make a call, It will hang right up. Anyone else having an issue with calling or how can I fix this?
Thank You
Chris
(02-15-2021, 03:40 PM)Csanderson0313 Wrote: One of the biggest issues that I see with the software is that I can not make calls. When I go to make a call, It will hang right up. Anyone else having an issue with calling or how can I fix this?
Thank You
Chris
Are you running the latest updates? There was a new call manager update today.
The best way to upgrade is from the terminal.
sudo apt-get update && sudo apt-get upgrade
Thank You
Chris
Also make sure your APN is set correctly. VoLTE will fail and cause the same problem if it's not.
Thank You
Chris
Thank You
Chris
Thank You Guys. The APN looks to be correct. Im downloading the update now to try it.
I jist had another calls update roll out to me. Version 0.3.0-1-0.3.0-2. You might want to check again?
Thank You
Chris
Thank You
Chris
I upgraded it but now it will not take my password to unlock the phone. Did the password changed? what is the new password to unlock?
Thank You
Chris
(02-16-2021, 05:04 AM)Csanderson0313 Wrote: I upgraded it but now it will not take my password to unlock the phone. Did the password changed? what is the new password to unlock?
Thank You
Chris
Sounds like you may be experiencing the problem described here: https://blog.mobian-project.org/posts/20...pam_issue/
Thank You
Chris
Thank You,
You was right and that fixed my issue. Mobian has came a long way then what it used to be. I started using UBuntu for months and found that no one is willing to help with issue much and that that the same issues been there for quite a while. I decided to switch back to Mobian to see how everything has been coming and wow big improvement. and most of everything is working. I think i will be staying with this software.
Thank You guys for all your help.
Thank You
Chris
Thank You,
There are updates and tweaks rolling out every day in anticipation of the Mobian CE edition Pinephone being shipped in a week. a-wai is really trying to make a good impression to the new owners and it's appreciated. We are noticing it and grateful. It's getting really good. Good enough for a daily driver for me. The only thing I would really like to see that I really need is Bluetooth calling and working alarms. A new modem manager just rolled out an hour ago to Mobian. It wakes your phone up on the first ring now. I was taking 3-4 and many people were missing calls. you really should run updates from the terminal a couple times a week with all the updates.
sudo apt update sudo apt dist-upgrade sudo apt autoremove
Thank You
Chris
Thank You,
To all those contributing, please don't take this badly Big Grin I don't want to offend / upset anyone (famous last words)
I don't doubt the good intentions of coders, whether paid or not, but when you get updates that suddenly create a massive battery drain / the modem just disappears and your phone has actually been disconnected for who knows how long.... not to mention incoming text message notifications that (still) don't seem to work reliably. Modem (still ? not tested recently) takes about 13 seconds to wake up from sleep and start ringing...
I know a lot of these are 'upstream' with Phosh et al. and I have no idea how 'Debian' or other OSes using phosh can actually help. Maybe its an ownership issue / too many coders, I don't know.
I guess it's a development 'device' at this stage and should be considered as such. Use it as a daily device knowing any update can break things, but will hopefully improve them. Smile
Shame it's not really a reliable 'phone' YET - you'd have thought getting the fundamentals would be a priority. Librem 5 shipping presumably helps but the Quectel modem doesn't seem to help with the Pinephone, I don't think? Awaiting the more open source firmware, perhaps?
I'm using it (probably stupidly) as a daily driver but I know I run the risk of it not ringing before someone gives up, that some text messages never trigger a notification....now I wonder if the modem is actually on ?! lol Confused
I wish there was an easy way to see updates and any fixes to issues that have just appeared. I presume the recommendation is to update asap to get the latest fixes. Presumably nasty regressions are unexpected side effects / coding errors - I naively wonder why nasty side effects are not spotted but perhaps the whole thing is too complex. I know testing can be very time consuming.
I'm hoping Mobian funding comes in to pay for development and help things along and that upstream fixes from Librem 5 / phosh tricke down eventually. I'm not a good enough programmer to help, unfortunately.
Thanks to a-wai and others contributing, particularly if you're doing it for free. I guess those of us who are just 'users' are just keen on having a device that works for us! Probably too keen for our own good - I know a recent post discussed these issues.
To all those contributing, please continue improving the Pinephone! long live the Pinephone! Heart
Rather than just complaining, I've lodged an issue at Mobian https://gitlab.com/mobian1/issues/-/issues/252
Hopefully I will be forgiven Angel
To post or not to post.....
On a more positive note, battery drain is now back to normal, not sure what happened when it was draining very quickly, results are here:
https://forum.pine64.org/showthread.php?...9#pid90019
  Printing from Mobian johnd 3 5,208 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,209 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,161 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 72,382 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,534 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,664 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 359,787 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,345 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,616 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,362 05-06-2025, 02:19 AM
