VoLTE calls with o2 (Germany)
Hello there,
did anyone manage to set up VoLTE calls with o2 (Germany)?
In my case (Mobian), the modem was automatically set to Telefónica Germany but the phone always switches to 3G for calls.
I'm curious, if other distros can do VoLTE calls with o2 (Germany) and if anyone could provide some help.
Thanks in advance!
This are maybe some good news to you. For me VoLTE on German Telefonica network is so far working well and I got an superior call audio quality.
I'm using pmOS edge on a Ubports CE with a Simplytel sim card by Drillisch. Reception indoors is sometimes problematic but otherwise fine.
As far as I know pmOS is using some AT Commands to select a custom VoLTE profile and sets my APN setting for mobile data automatically.
Their wiki gives you more information about how they are doing it and there is even a request to enable it in Mobian in the near future.
If I were you, I would try to follow their instructions and put them in startup script that is executed on boot. See the Mobian =rc]wiki for a way to do so.
Since I also got only 2G calls while I was using MedionMobile, it is possible that some cheaper providers are not able to do VoLTE on Telefonica Network.
From your post I understand that you are using a O2 plan and should get VoLTE. If above steps are working, please report back on the Mobian to get this merged more quickly.
(02-03-2021, 08:35 AM)synQun Wrote: This are maybe some good news to you. For me VoLTE on German Telefonica network is so far working well and I got an superior call audio quality.
Thanks for your answer. Since my modem is already set to
+QMBNCFG: "List",9,1,1,"TF_Germany_VoLTE",0x05010C1B,201909201
indicated by the two "1"s, it seems I'll have to wait for the new modem driver and see, if this brings me VoLTE.
Really glad to hear there is at least some hope of VoLTE working! It's something I have been worrying about on the horizon...
Of course, things are different here in US. Maybe I should find another thread about that more specifically (or make one).
Cheers!
Cheers,
TRS-80
Protocols, not Platforms
Finally...
After a long period of trial&error, my VoLTE with o2 (Germany) works on Mobian. And it was quite easy after all...
Here is what I did:
Disable VoLTE profile autoselection
mmcli -m any --command='AT+QMBNCFG="AutoSel",0'
Select the generic VoLTE profile
mmcli -m any --command='AT+QMBNCFG="Select","ROW_Generic_3GPP"'
Restart the modem
mmcli -m any --command='AT+CFUN=1,1'
Check the selected VoLTE profile with
mmcli -m any --command='AT+QMBNCFG="List"'
Check the VoLTE status with
mmcli -m any --command='AT+QCFG="ims"'
--> response should be
Quote:'+QCFG: "ims",1,1'
if it shows "1,0", checking and disabling the phone's "Aeroplane Mode" might help (it was magically on after the reset in my case)
Change the Network Mode in "Settings - Mobile" to "4g Only" and make a test call. It should work.
Cheers!
Hi guys.
I followed you thread and gathered enough hope to try it again. I have tried before to no avail, and this time it ended as the last.
Whatever I configure my modem to do, it does not enable VoLTE but switches to 3G, loses its signal (because 3G i weak) and fails the call.
Any suggestion to wjat I can try?
Oh, and when I try the same SIM in my "moto 8G" with android, it does VoLTE like a charm....sigh. I really want to use my pinephone.
Cheers!
(06-09-2021, 10:29 AM)asz Wrote: Hi guys.
Cheers!
Have you tried to force your phone to use 4G by choosing "4G only" in the Settings?
  Public Mobile (Canada): failure to configure VoLTE digdis 6 171 Yesterday, 04:17 PM
Last Post: digdis
  4G VoLTE calls confirmed working with carrier x dcinoz 16 21,027 01-25-2025, 01:34 PM
Last Post: lm2
  pinephone with lte-m chip and volte zetabeta 0 1,336 10-02-2023, 05:42 AM
Last Post: zetabeta
  Buetooth handsfree calls on PinPhone alabasha 7 4,774 08-18-2023, 09:29 AM
  pinephone no longer receiving calls or texts jyoung 3 3,629 07-16-2023, 10:05 PM
Last Post: jyoung
  Handsfree bluetooth calls conifera 0 1,509 02-28-2023, 02:07 PM
Last Post: conifera
  Calls, SMS benedikt55 1 1,979 12-13-2022, 10:42 AM
Last Post: treebeard
  Can you make reliable calls yet? orbital 26 20,773 10-11-2022, 10:52 PM
Last Post: better
  phone calls are enough for now wehape2bees 2 3,146 07-30-2022, 06:06 PM
Last Post: zetabeta
  Mute function on calls? scrwbigtek 0 1,278 05-30-2022, 12:52 PM
Last Post: scrwbigtek
