power on button attach where
there was a power button shipped with the pine64. Where do I attach it to the board?
(05-29-2016, 09:09 AM)BringItOn Wrote: Hi,
It can be attached as either a power or reset switch, shown on this diagram, labelled 'for Reset button', or 'for Power ON/OFF button' (over on the right hand side of the diagram).
I didn't get a button, was that an add on?
Also, speaking of power,, how do you power it down when running android? via the OS?
You can install a shutdown icon app but the Android need to be rooted version.
My power button was losse in the package, so might be worth to double check?
Here some images to illustrate the installation, just make sure you earth yourself first (touch uncoated metal that is in contact with the ground)
  New RockPro64 Power Up Problem enorbet2 7 14,459 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 3,630 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,713 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,608 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 25,163 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,663 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 8,233 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 12,320 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,206 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 9,874 10-23-2016, 12:16 PM
Last Post: dkryder
