New PBP crashing every 5 min
Started up my new PBP this morning, install goes well.  A few minutes after initial boot, the screen freezes - I can use the mouse but nothing works.  Tried letting it sit for 5 minutes or so, no dice.  Had to shutdown.  Have restarted 5 times now and the same issue issue persists.  Can’t seem to do anything in settings or terminal before it freezes.  Any advice??
Thanks for reading Smile
I only have a small bit of advice to offer, hopefully someone else will be able to add on later.
Testing with a micro sd card will let you know wether the hardware is at fault or not. Meaning that if you set up an sd card with any distro on it and do nothave the same issues, there is a problem with either the EMMC itself or the stock OS install was borked somehow
Also try an OS that doesn't default to overclocking.
  KDE crashing bastafari 2 6,237 10-01-2020, 10:48 AM
Last Post: bastafari
  Chromium Crashing if not Superuser cmelcher 3 7,479 12-13-2019, 07:43 AM
Last Post: cmelcher
