Did the pinephone 1.2a board undergo certifications?
Or was certification of the 1.2 boards "good enough"?
(10-10-2020, 12:00 PM)desca Wrote: Or was certification of the 1.2 boards "good enough"?
PCB v1.2a is identical to v1.2 with two components removed replaced. There was no need for the device to be re-certified again.
Just out of curiosity, do you know what makes a change significant enough to trigger recertification?
Any change to major components (ICs, transformers, antenna design) that leads to different functioning or specifications. There's a bit of info on this page for a company that helps clients certify (there is a section or two specifically mentioning licensed devices like mobile phones):
https://www.cetecom.com/en/certification...ification/
it doesn't get happy
it doesn't get sad
it just runs programs
Thank you. That makes sense to me that the FCC, at least, may be satisfied as long as you aren’t doing anything to the radio or maybe likely interference sources.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,034 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,945 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,548 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,672 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,158 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,722 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,723 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,306 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,433 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,989 03-25-2025, 08:51 PM
