Mobian
Hey all
I installed Mobian on my PinePhone and loved it
2 errors
when my phone is in idle mode my screen keeps popping up the date and time, can I switch it of to save battery?
The big issue I have is that when I play music on is, my volume buttons dont work, I can switch my music lower or higher, does anyone has a fix on it please
Regards
The volume buttons do not yet work in phosh, but there is a MR for phosh/phoc which should be merged pretty soon,
so that should probably be working some time next week ;)
There are some events which trigger a wakeup of the phone (periodically?). Personally I do not quite know what their origin is.
(07-23-2020, 12:56 PM)devrtz Wrote: The volume buttons do not yet work in phosh, but there is a MR for phosh/phoc which should be merged pretty soon,
so that should probably be working some time next week Wink
Thanks very much
(07-23-2020, 12:13 PM)jesica Wrote: ...
Yeah a known issue (and complete PITA as was previously sorted on 5.6 kernel) so hopeful a fix will be with us soon. One thing I find is this seems to be an artefact of something I do and on a clean rebooted system it is more liklely to settle and engage CRUST!
The workaround: Just tap the status bar at top of screen and use the slider. Again (as per devrtz) hopefully wont be too long until phosh gets there.
(07-23-2020, 12:13 PM)jesica Wrote: The big issue I have is that when I play music on is, my volume buttons dont work, I can switch my music lower or higher, does anyone has a fix on it please
This works as of yesterday evening.
Be careful with the update though:
https://forum.pine64.org/showthread.php?tid=10965
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 16 2,052 8 hours ago
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,785 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 134 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,009 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,831 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 636 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,924 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,905 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 634 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,029 06-19-2023, 03:02 PM
Last Post: vusra
