no calls after changing screen
Everything is working accept modem. all connections seem fine. The modem gets warm so I'm assuming its getting power. What am I missing?
Are you getting any signal reading from the modem? Either in status bar or Settings, Mobile, Modem details?
My "reserve" phone does not work because the micro co-ax cable that connects the main board to the bottom USB-C connector board does not connect (mainly as I pulled the connector off the USB-C slave board the 1st time I tried to remove the cable. So modem sort of looks OK but signal level is unusable. Just a thought
there are dozens of checks that can be performed, first you check the hardware connections, then you run mmcli if you are using ModemManager (phosh) or ofonoctl if you are using ofono (plasma), then you can check the DBus and last the AT commands, have a look at my guide for the Quectel Mobile Data Configuration
  4G VoLTE calls confirmed working with carrier x dcinoz 17 39,180 10-07-2025, 11:05 AM
Last Post: baptx
  PinePhone Boots but only Shows Black Screen with Backlight danyeaw 1 3,163 06-30-2024, 10:18 AM
Last Post: danyeaw
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 13,940 08-28-2023, 11:38 AM
Last Post: fxc
  Buetooth handsfree calls on PinPhone alabasha 7 8,943 08-18-2023, 09:29 AM
  pinephone no longer receiving calls or texts jyoung 3 6,252 07-16-2023, 10:05 PM
Last Post: jyoung
  locked out on PIN screen g40 1 2,969 06-07-2023, 10:20 PM
  Handsfree bluetooth calls conifera 0 2,438 02-28-2023, 02:07 PM
Last Post: conifera
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 12,705 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 2,870 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 2,242 01-03-2023, 06:17 PM
