Fix your Pinebook Pro speaker connection
@dsimic the wires are "punched down" in the connector. I find that the wires can simply be torn out of the connector, by pulling at a right angle. They can be punched down with a small flat-blade screwdriver.
This is probably the smallest thing I can successfully work on without specialised machinery and magnification. I thought it would be much harder than it it.
:wq
(07-08-2021, 12:51 AM)Kaythe Wrote: Well if you have a soldering iron you can always cut the wires and reconnect them black<->red. Put some heatshrink tube over it and that should work. It's not a "good" solution but certainly easier than rewiring the connector.
You're right, but I prefer to keep the end result looking "stock" as much as possible.  Furthermore, my conclusion was directed toward evaulating the ability of an "average" PineBook Pro user to rewire the speaker connector.
(07-08-2021, 12:56 AM)KC9UDX Wrote: @dsimic  the wires are "punched down" in the connector.  I find that the wires can simply be torn out of the connector, by pulling at a right angle.  They can be punched down with a small flat-blade screwdriver.
You're right, the pins inside the speaker connector are not supposed to come out of the connector.  In the factory, the speaker wires are probably threaded through the small openings on the side of the connector and "punched down" into the pins.  The issue with puling the wires out of the pins is that the "slit" parts of the openings on the side of the connector aren't large enough for the wires to slide through them.
Of course, the wires can be ripped out of the pins with enough force applied, but I simply didn't see applying that much force as a viable option.  Furthermore, the connector is really small so it's hard to hold it firmly while applying force to the wires.
(07-08-2021, 12:56 AM)KC9UDX Wrote: This is probably the smallest thing I can successfully work on without specialised machinery and magnification.  I thought it would be much harder than it it.
I had to use a magnifying glass. Smile  Maybe my eyes were too tired.
I held the connector with a pliers. The conductors pulled out without much effort.
:wq
  Replacement battery for PineBook Pro DrYak 5 6,703 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,943 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,521 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 4,122 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,672 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,634 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,153 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 211,420 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 13,599 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 12,050 12-27-2022, 03:31 PM
Last Post: samtux
