Wrong PIN error
Just setting up a new Pinephone with the stock Manjaro OS and getting a 'wrong PIN' error, despite checking a few times when setting up the phone the PIN I would use.
How can I re-run the setup/installation process again? There doesn't appear to be a factory setting or recovery mode option.
I had similar issue though seemed to correct itself after 30mins.
I wsnt sure if it was an OS or deeper issue.
Hopefully someone answers.
Quote:Has anyone tried to connect via SSH? I tried to find answers on the Manjaro forum and buy case study from the official dev's portal. They offer paid tutorials.
I had the 'wrong PIN' error after some minor updates via Discover. So I was trying to ssh to my PinePhone from my Mac with Ubuntu in VirtualBox. sshd should be manually enabled in PinePhone.
Did you manage to deal with the problem? I'm interested to know
  What is wrong with the Mobian signature key? Mahgue 0 797 11-08-2025, 05:13 AM
Last Post: Mahgue
  discover packages error lash 3 3,216 02-14-2024, 03:20 PM
  SD Card has wrong capacity AndyM 11 8,872 06-11-2023, 12:30 AM
Last Post: AndyM
  Error while dist upgrade PostmarketOS shellchocolat 0 1,991 03-16-2023, 02:56 AM
Last Post: shellchocolat
  Boot problem: wrong screen orientation Jetpac 6 7,758 07-18-2022, 12:47 PM
Last Post: fravoi
  Flashing gone wrong erg 9 10,648 05-28-2022, 10:52 AM
Last Post: fxc
  pcmanfm root permission error Dinosaur1946 4 5,704 01-11-2022, 06:52 PM
Last Post: Dinosaur1946
  mmc_erase: group start error -110, status 0x0 gab 1 4,318 06-26-2021, 07:00 PM
Last Post: 8bit
  Wrong language installed on PINE64 mobian edition Derek7 0 3,035 04-02-2021, 05:25 PM
Last Post: Derek7
  Trying to diagnose what's wrong... m16a1 6 9,823 02-24-2021, 08:45 PM
Last Post: C0ffeeFreak
