discover packages error
Since I got my pinephone early last year, any attempt at installing packages from discover has resulted in an error message popup saying "<pkgname>;<version>;aarch64,extrra: could not find or read package" when browsing to the application profile page.
All packages are also listed as 0b.
Sometimes images don't load.
Is there something I need to do, or should I be using a different OS?
I am currently using Pinephone "convergence edition" with manjaro beta 15.
Thanks.
(02-14-2024, 07:32 AM)lash Wrote: Since I got my pinephone early last year, any attempt at installing packages from discover has resulted in an error message popup saying "<pkgname>;<version>;aarch64,extrra: could not find or read package" when browsing to the application profile page.
Thanks.
Would recommend to update and install packages via command line, using pacman.
Generally there are more stable distributions, which won't have such issues and you will probably enjoy more.
Thanks.
I would not mind a recommendation for a more stable distro. Especially one that supports the plasma desktop environment, which I've already started working with to create app. Or maybe there is a thread somewhere here for that already? thanks.
If you want a working graphical package manager, install pamac-gtk and pamac-mobile-integration. It will also work under Plasma Mobile.
Discover uses PackageKit, which basically does not work on Arch-based distributions (since the switch to Pacman 6 a couple years ago).
  Error while dist upgrade PostmarketOS shellchocolat 0 2,589 03-16-2023, 02:56 AM
Last Post: shellchocolat
  pcmanfm root permission error Dinosaur1946 4 6,761 01-11-2022, 06:52 PM
Last Post: Dinosaur1946
  Wrong PIN error lordearl 3 7,393 09-20-2021, 03:19 AM
Last Post: mcdanielmark473
  mmc_erase: group start error -110, status 0x0 gab 1 5,230 06-26-2021, 07:00 PM
Last Post: 8bit
