alsamixer and audio scale settings- how to make persistent
Can get usable sound on speakers by setting card to rk... (not default) and increasing volume of "headphones" ? to max and by increasing audio scale to 150% in system settings: audio. But the settings are not persistent. They disappear on rebooting and at other times during use.
Someone mentioned a fix but I can't find it. Thanks for any tips.
Edit: the alsamixer is set back to the "default" card choice when the sound goes back to very low volume. If I re-choose the rk... card, the volume goes back up. I think this is happening when listening to a series of you tubes. Maybe the default setting could be set to the rk... card in some config file. Have each choice be the same?
  Audio Issues alvinsmith 1 2,496 08-10-2024, 01:50 AM
Last Post: sparkie
  NUMA NUMA make Raspberry Pi go ZOOMA -> PBPro? Tazdevl 1 3,024 07-19-2024, 04:34 AM
Last Post: Tazdevl
  Lockable-until-power-cycle persistent storage Melab 0 2,666 09-17-2023, 08:51 PM
Last Post: Melab
  how to make a bootable USB linux sine pinebook will not boot up River 14 16,557 12-11-2022, 11:12 PM
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 4,659 10-01-2022, 10:16 AM
Last Post: crazyquark
  No audio from HDMI with usb-c adapter rfm83 5 15,172 06-19-2022, 09:06 PM
Last Post: rfm83
  Workaround for crackling audio when music starts/stops pato3 1 5,146 07-28-2021, 12:26 PM
Last Post: dsimic
  Flickering black window when opening settings Edgars10 0 3,133 06-06-2021, 05:42 AM
Last Post: Edgars10
  Keyboard settings not saved on reboot motezart 6 13,065 11-26-2020, 12:11 PM
Last Post: creaverse
  Audio with Debian GloriousCoffee 5 12,833 10-15-2020, 01:22 PM
Last Post: Mangled
