NUMA NUMA make Raspberry Pi go ZOOMA -> PBPro?
Would this work on the PBPro?
https://www.youtube.com/watch?v=2ZrVyFCkOew
(07-17-2024, 01:26 AM)Tazdevl Wrote: Would this work on the PBPro?
It should work I guess?
https://www.cnx-software.com/2024/06/27/...platforms/
issue is though... How?
https://www.jeffgeerling.com/blog/2024/n...provements
Evaluating the patch is a little involved (especially if you're not familiar with compiling the Linux kernel):
Download the .mbox file for the kernel patch thread.
Apply it to your raspberrypi/linux checkout with git am [filename.mbox]
Rebuild the Linux kernel, ensuring NUMA Emulation is enabled in the kernel config.
Add numa=fake=4 to /boot/firmware/cmdline.txt before the rootwait option, and reboot.
Prefix any commands you want to test with numactl, e.g.: numactl --interleave=all ./geekbench6. (Install numactl with sudo apt install -y numactl.)
There is no /boot/firmware on pine Smile
  Endeavour OS on Pbpro rfm83 11 14,215 01-01-2023, 08:47 PM
Last Post: rfm83
  how to make a bootable USB linux sine pinebook will not boot up River 14 17,348 12-11-2022, 11:12 PM
  alsamixer and audio scale settings- how to make persistent straightwalker 0 3,256 06-04-2021, 10:57 AM
Last Post: straightwalker
  Pbpro is sluggish flatulent_piney 3 6,634 02-15-2021, 11:04 AM
Last Post: User 17828
  power light blinking during charge when pbpro is off Idaho 0 4,341 01-04-2021, 10:53 AM
Last Post: Idaho
  Pinebook Pro performance vs. Raspberry Pi 4? yangmusa 2 12,842 02-06-2020, 01:40 AM
Last Post: xmixahlx
  How to make Time change persistent FeMike 4 8,561 01-23-2020, 08:24 PM
Last Post: FeMike
  How can i make pre-order ?? erosketak 1 5,027 10-08-2019, 03:58 PM
Last Post: bcnaz
