Android sources
Hey, where can I find the sources for Android (special for Pine64) to rebuild own firmware?
the wiki gives only finals img files, I'd like to remake it for myself.
I guess I need kernel sources
Android sources
And is there any instructions how to build your own firmware?
Look for the Binary Source Packages (BSP)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(05-14-2016, 08:36 AM)lenny.raposo-pine64.pro Wrote: Look for the Binary Source Packages (BSP)
Thanks for your reply!
I missed this section )
So, where can I find readme how to build it and set up the environment?
I found environment on google dev site.
I'm trying to make own build, what 's device I must choose for making it for A64 when I use lunch command
I have the next list:
You're building on Linux
Lunch menu... pick a combo:
    1. aosp_arm-eng
    2. aosp_arm64-eng
    3. aosp_mips-eng
    4. aosp_mips64-eng
    5. aosp_x86-eng
    6. aosp_x86_64-eng
    7. aosp_flo-userdebug
    8. mini_emulator_arm64-userdebug
    9. m_e_arm-userdebug
    10. mini_emulator_mips-userdebug
    11. mini_emulator_x86-userdebug
    12. mini_emulator_x86_64-userdebug
    13. aosp_flounder-userdebug
    14. aosp_shamu-userdebug
    15. aosp_manta-userdebug
    16. astar_h7-eng
    17. astar_h7-user
    18. astar_y3-eng
    19. astar_y3-user
    20. astar_yh-eng
    21. astar_yh-user
    22. jasmine_perf-eng
    23. jasmine_perf-user
    24. kylin_p1-eng
    25. kylin_p1-user
    26. kylin_p2-eng
    27. kylin_p2-user
    28. octopus_f1-eng
    29. octopus_f1-user
    30. octopus_ibt-eng
    31. octopus_ibt-user
    32. octopus_n1-eng
    33. octopus_n1-user
    34. octopus_perf-eng
    35. octopus_perf-user
    36. tulip_p1-eng
    37. tulip_p1-user
    38. tulip_perf-eng
    39. tulip_perf-user
    40. tulip_t1-eng
    41. tulip_t1-user
Which would you like?
(05-15-2016, 03:05 PM)IlyaM Wrote: I found environment on google dev site.
    1. aosp_arm-eng
    2. aosp_arm64-eng
    3. aosp_mips-eng
    4. aosp_mips64-eng
    5. aosp_x86-eng
    6. aosp_x86_64-eng
    16. astar_h7-eng
    17. astar_h7-user
    18. astar_y3-eng
    19. astar_y3-user
    20. astar_yh-eng
    21. astar_yh-user
    24. kylin_p1-eng
    25. kylin_p1-user
    26. kylin_p2-eng
    27. kylin_p2-user
    28. octopus_f1-eng
    29. octopus_f1-user
    30. octopus_ibt-eng
    32. octopus_n1-eng
    33. octopus_n1-user
    36. tulip_p1-eng
    37. tulip_p1-user
    38. tulip_perf-eng
    39. tulip_perf-user
    40. tulip_t1-eng
    41. tulip_t1-user
tulip_t1-eng
(05-16-2016, 07:26 AM)Hahaburger Wrote: tulip_t1-eng
Thanks!
Now I have another problem, I set up oracle jdk7
But every time I get an issue
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=5.1.1
TARGET_PRODUCT=tulip_t1
TARGET_BUILD_VARIANT=eng
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=generic
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv7-a-neon
TARGET_2ND_CPU_VARIANT=cortex-a15
HOST_ARCH=x86_64
HOST_OS=linux
HOST_OS_EXTRA=Linux-4.4.0-22-generic-x86_64-with-Ubuntu-16.04-xenial
HOST_BUILD_TYPE=release
BUILD_ID=LVY48E
OUT_DIR=out
Checking build tools versions...
You asked for an OpenJDK 7 build but your version is
java version "1.7.0_80" Java(TM) SE Runtime Environment (build 1.7.0_80-b15) Java HotSpot(TM) 64-Bit Server VM (build 24.80-b11, mixed mode).
when I try to install openjdk
apt-get install openjdk-7-jdk
I got a message that you have to choose from the list
  oracle-java9-installer 9b116+9b116arm-1~webupd8~1
  oracle-java8-installer 8u92+8u91arm-2~really8u91~webupd8~0
  oracle-java7-installer 7u80+7u60arm-0~webupd8~1
How to solve this problem with idk?
(05-16-2016, 07:43 AM)IlyaM Wrote: when I try to install openjdk
Weird, maybe it was installed idk. Maybe you can try these:
sudo update-alternatives --config java
sudo update-alternatives --config javac
if you see openjdk in output, select it.
(05-16-2016, 08:17 AM)Hahaburger Wrote: Weird, maybe it was installed idk. Maybe you can try these:
There is only one line:  /usr/lib/jvm/java-7-oracle/jre/bin/java
and there are no alternatives
I tried to reinstall that, removing everything with java, the same issue
maybe do I need remove $JAVA_HOME from environment?
(05-16-2016, 08:21 AM)IlyaM Wrote: There is only one line:  /usr/lib/jvm/java-7-oracle/jre/bin/java
I don't think you need to remove JAVA_HOME first you should install openjdk
If you are using Ubuntu have you tried searching openjdk on software center?
(05-16-2016, 08:30 AM)Hahaburger Wrote: I don't think you need to remove JAVA_HOME first you should install openjdk
Finally got it
sudo add-apt-repository ppa:openjdk-r/ppa
sudo apt-get update
sudo apt-get install openjdk-7-jre
Do you know what does this line mean?
CHIPHD_LICHEE_DIR=builder@192.168.1.22:/home2/builder/release/a83-5.1/lichee
root@ilya-eME730G:/media/ilya/Data/A64/android# . build/envsetup.sh
including device/asus/flo/vendorsetup.sh
including device/generic/mini-emulator-arm64/vendorsetup.sh
including device/generic/mini-emulator-armv7-a-neon/vendorsetup.sh
including device/generic/mini-emulator-mips/vendorsetup.sh
including device/generic/mini-emulator-x86/vendorsetup.sh
including device/generic/mini-emulator-x86_64/vendorsetup.sh
including device/htc/flounder/vendorsetup.sh
including device/moto/shamu/vendorsetup.sh
including device/samsung/manta/vendorsetup.sh
including device/softwinner/astar-h7/vendorsetup.sh
including device/softwinner/astar-y3/vendorsetup.sh
including device/softwinner/astar-yh/vendorsetup.sh
including device/softwinner/common/vendorsetup.sh
including device/softwinner/jasmine-perf/vendorsetup.sh
including device/softwinner/kylin-p1/vendorsetup.sh
including device/softwinner/kylin-p2/vendorsetup.sh
including device/softwinner/octopus-f1/vendorsetup.sh
including device/softwinner/octopus-ibt/vendorsetup.sh
including device/softwinner/octopus-n1/vendorsetup.sh
including device/softwinner/octopus-perf/vendorsetup.sh
including device/softwinner/tulip-p1/vendorsetup.sh
including device/softwinner/tulip-perf/vendorsetup.sh
including device/softwinner/tulip-t1/vendorsetup.sh
including device/softwinner/zzzzz-chiphd/vendorsetup.sh
I got it when I use . build/envsetup.sh
It highlighted red
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,899 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 587,907 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 48,244 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 30,801 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,168 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,562 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,113 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,444 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 395,436 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,171 02-26-2019, 11:58 AM
Last Post: Twistedx
