Start-Up Advice
Hi all
I had some of the same troubles getting my board to boot.
Plugged board into HDMI input on TV and booted right up.
I also had the issue with red power LED turning off. I swapped out the power supply with a spare
5V supply from an old cell phone to resolve that.
I'm running the Debian OS, downloaded from Pine64 Wiki site. I tested without ethernet plugged in. The boot process pauses for about 2 minutes as it looks for an active LAN connection. After that, login prompt displays and all seems OK.
Hope this helps!
(05-15-2016, 10:55 PM)irobot Wrote: Hi all
Hope this helps!
Yup, the OS waits for an Ethernet connection. If you plug in the Ethernet cable it will boot up quicker.
Side note: please check what amps the 5V puts out --- 2A or more is preferable. Some cell phone chargers have lower outputs. If you use a charger with less than 5V 2A you may run into problems when the system experiences load.
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,608 03-18-2021, 11:52 AM
Last Post: Avron
  advice requested for purchase Ikke 5 12,043 02-13-2018, 02:00 PM
Last Post: Luke
  Where do I start? dhewko 6 12,805 06-16-2016, 03:55 AM
Last Post: dhewko
  Can't get it to start up yourhighpriestess 31 65,642 04-26-2016, 01:12 PM
Last Post: artus
