Rock64 CRUX-ARM (aarch64)
Source based Linux distribution CRUX-ARM adhering to ideology keep it simple, has its own package system, also supports the port system.
the image building system now supports slaсkwarearm, slarm64, crux-arm
crux-arm-3.6-aarch64-core-rock64-5.12.6-build-20210527.img.zst
crux-arm-3.6-aarch64-core-rock64-5.12.6-build-20210527.img.zst.sha256
# DDR version 1.16 20190528
In
LPDDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB
ddrconfig:7
OUT
U-Boot SPL 2021.04-rk3328 (May 27 2021 - 20:41:34 +0300)
Trying to boot from MMC1
NOTICE:  BL31: v2.5(release):v2.5-dirty
NOTICE:  BL31: Built : 20:39:09, May 27 2021
NOTICE:  BL31:Rockchip release version: v1.2
U-Boot 2021.04-rk3328 (May 27 2021 - 20:46:24 +0300)
Model: Pine64 Rock64
DRAM:  4 GiB
PMIC:  RK8050 (on=0x50, off=0x01)
MMC:   mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
1689 bytes read in 5 ms (329.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
51 bytes read in 4 ms (11.7 KiB/s)
51717 bytes read in 9 ms (5.5 MiB/s)
28723712 bytes read in 1249 ms (21.9 MiB/s)
libfdt fdt_getprop(): FDT_ERR_NOTFOUND
Failed to load '/boot/uInitrd'
Moving Image from 0x2080000 to 0x2200000, end=3e00000
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Device Tree to 00000000fcebb000, end 00000000fcf2ffff ... OK
Starting kernel ...
[    1.255013] rockchip-pinctrl pinctrl: pin gpio0-2 already requested by vcc-host-5v-regulator; cannot claim for vcc-host1-5v-regulator
[    1.255083] rockchip-pinctrl pinctrl: pin-2 (vcc-host1-5v-regulator) status -22
[    1.255117] rockchip-pinctrl pinctrl: could not request pin 2 (gpio0-2) from group usb20-host-drv  on device rockchip-pinctrl
[    1.255155] reg-fixed-voltage vcc-host1-5v-regulator: Error applying setting, reverse things back
[    3.053233] gpio-syscon ff100000.syscon:grf-gpio: can't read the data register offset!
[    3.251911] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
CRUX-ARM 64b (rock64) (ttyS2)
rock64 login: root
Password:
Last login: Thu Jan 21 08:52:04 UTC 2016 on tty1
___  ___  _ _  _ _  ___  ___  ___  _____
|  _||  _|| | ||_'_||___|| .'||  _||     |
|___||_|  |___||_,_|     |__,||_|  |_|_|_|
                _    ___  ___
___  ___  ___ | |_ |  _|| | |
|  _|| . ||  _|| '_|| . ||_  |
|_|  |___||___||_,_||___|  |_|
donation   irradium
crux-arm-3.6-aarch64-core-rock64-5.15.10-build-20211221.img.zst
crux-arm-3.6-aarch64-core-rock64-5.15.10-build-20211221.img.zst.sha256
donation   irradium
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,226 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,809 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 96,388 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,032 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,435 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,444 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,932 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,105 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,999 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,684 09-01-2024, 06:05 AM
Last Post: RaymondDay
