Can't update OS Mobian Phosh
Hi all,
I've just installed Mobian Phosh on my Pinephone flashing it on my SD card. I find it incredibly useful, fast and easy to use, but waiting for improves to come.
I find a problem now when I try to update the Operative system or when I try to install any other software. I can't do it because, as it notifies me, executing dpkg was interrupted, and I have to execute it manually "dpkg --configure -a" to fix the problem.
The other problem I have, is that I can't find terminal to try to fix that, and I can't install it because of the same issue.
Thanks a lot for helping me,
Gon.
(05-22-2021, 02:39 PM)Gon Wrote: ...
The terminal is the application called Kings Cross, a reference to one of the largest railway terminals in London!
Once you get going you may prefer (as I do) to remove the software application and to do your software maintenance directly in the terminal using apt.
Have fun
Thanks so much! I thought Kings Cross was a travelling software Smile)
I tried my first update using the GUI software update program like you did and ran into a similar but worse issue (OS didn't work at all) and had to re-install and instead do the first update from the terminal with apt, which worked without a problem. Note, the first update that generates initramfs is a little scary because it takes a long time to generate it and during that time it is easy to wonder if something is wrong. If the phone isn't plugged in, you may need to periodically wake it up to get it to finish.
I always ssh into the phone and use the command line. Also it seems like a good idea to keep the phone plugged in while updates are installing.
You can also adapt one of the suspend/sleep tweaks here
https://wiki.mobian-project.org/doku.php...pend-sleep
to prevent the phone from sleeping when using apt/apt-get..
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 2 2,656 Yesterday, 11:26 AM
Last Post: kirkaso
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 49,330 12-24-2025, 12:11 AM
  No touch KB after update(forky) biketool 4 769 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 1,046 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 35 63,132 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 30,415 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,386 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 293,599 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,158 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,813 06-07-2025, 03:19 PM
