An unofficial Debian Installer for Pinebook Pro
@danielt: Is the installer meant to work for booting from the USB slots?
After installing to a USB and attempting to boot from it, the Pinebook Pro just powers on with a black screen.
The same happened when I tried to boot my existing SD card installation through a USB slot via an SD-to-USB adapter.
I ask because I'm getting "IO error" when doing `cryptsetup open` on a certain SD card. I don't get the error when using an SD-to-USB adapter, so I'm worried that this is a sign of a failing SD slot. (Pinebook Pro is only 1-year old!) It would be much more reassuring (for recovery purposes) if I can boot from USB instead of SD.
I don't think boot from USB works, never looked into it.
Good news, everyone!
Latest official Debian kernel package (5.10.0-7) boots fine on PBP, with working screen and all.
This message was created with 100% recycled electrons
(05-21-2021, 11:34 PM)moonwalkers Wrote: Good news, everyone!
It is worth noting that this is only available on sid currently, but should be in testing soon(ish) I believe the package version was linux-image-arm64 5.10.38-1.
Hello --- thanks very much for making this installer; I would love to run stock Debian on my new PBP. Note that I say 'would love', because while the installer runs fine, it kernel panics on boot...
The crash happens at T+13s, well into multiuser startup, and I've pasted the relevant bits blow (does this forum have an attach button? I can't find one). The reference to gpio-key-power looks suspicious.
The kernel version the installer used is linux-image-pinebookpro-arm64 (5.7.19-30-geadcd756eb47-1). Is this new, by any chance?
[   11.094664] raid6: neonx2   gen()  2396 MB/s
[   11.264662] raid6: neonx2   xor()  1654 MB/s
[   11.434664] raid6: neonx1   gen()  2065 MB/s
[   11.456511] input: gpio-key-power as /devices/platform/gpio-key-power/input/input9
[   11.456641] Unable to handle kernel write to read-only memory at virtual address ffff000002df9000
[   11.462979] Mem abort info:
[   11.463231]   ESR = 0x9600004e
[   11.463507]   EC = 0x25: DABT (current EL), IL = 32 bits
[   11.463975]   SET = 0, FnV = 0
[   11.464247]   EA = 0, S1PTW = 0
[   11.464527] Data abort info:
[   11.464784]   ISV = 0, ISS = 0x0000004e
[   11.465124]   CM = 0, WnR = 1
[   11.465393] swapper pgtable: 4k pages, 48-bit VAs, pgdp=00000000033d0000
[   11.465981] [ffff000002df9000] pgd=00000000f7ff8003, pud=00000000f7ff7003, pmd=0060000002c00791
[   11.466751] Internal error: Oops: 9600004e [#1] PREEMPT SMP
[   11.467242] Modules linked in: btsdio hci_uart brcmfmac btqca btbcm btintel rockchip_rga gpio_keys(+) raid6_pq(+) panfrost videobuf2_dma_sg bluetooth hid_multitouch(+) dw_wdt ecdh_generic ecc cw2015_battery snd_soc_hdmi_codec configfs dm_crypt gpu_sched nf_defrag_ipv6 pwm_fan cfg80211 rfkill brcmutil nvme nvme_core snd_soc_simple_amplifier snd_soc_rockchip_i2s snd_soc_rockchip_pcm rockchip_thermal rockchipdrm analogix_dp dw_hdmi snd_soc_es8316 panel_simple cec dw_mipi_dsi drm_kms_helper syscopyarea rockchip_saradc sysfillrect sysimgblt fb_sys_fops uvcvideo drm pwm_bl snd_soc_simple_card snd_soc_simple_card_utils drm_panel_orientation_quirks
[   11.472245] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 5.7.0-2-pinebookpro-arm64 #1
[   11.472909] Hardware name: Pine64 Pinebook Pro (DT)
[   11.473342] pstate: 000001c5 (nzcv dAIF -PAN -UAO)
[   11.473776] pc : __memcpy+0x48/0x180
(06-02-2021, 03:02 PM)hjalfi Wrote: Hello --- thanks very much for making this installer; I would love to run stock Debian on my new PBP. Note that I say 'would love', because while the installer runs fine, it kernel panics on boot...
Hi!
It would be best to create a new thread for help on this so that it can get more attention and it wont be buried in the old thread.
  Boot Order in Pinebook Pro food 12 17,324 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,652 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,860 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,912 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,121 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 118,003 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,484 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,905 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 16,776 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,913 12-13-2023, 07:22 PM
Last Post: trillobite
