Pine Phone Desktop Mode or "Standard" Gnome Desktop on PinePhone?
I'd like to install a standard mobian/debian distribution to use my pinephone as a very small desktop replacement with a fullsize BT Keyboard + Mouse but  I got many of small Problems which are real showstoppers right now....
- The Display is still vertical and I see no way how to configure it to be 'normal' horizontally orientated, even after modifying the xorg.conf (or wayland)
- despite the fact I uninstalled (purged) POSH  it still boots automatically into the "old" system - gdm3 is installed but is ignored anyway...
- I don't get any framebuffer bootscreen with the kernel messages as all other devices do... don't know why my parameters while booting are absolutely ignored, it seems?
Maybe it's the wrong way to take a mobian an uninstall all "unneccessary" stuff from it, maybe there is a better way to start off a 'minimal debian' image on the phone?
Thanks a lot!
Cheers
4920441
If you follow the instructions in https://wiki.mobian-project.org/doku.php...ble%20gdm3 you should get get your gdm3 environment on reboot. That will probably sort out the orientation issue too. No idea on the other q's, but I'm sure someone will have...
Cheers
(04-06-2021, 05:34 AM)4920441 Wrote: - despite the fact I uninstalled (purged) POSH  it still boots automatically into the "old" system - gdm3 is installed but is ignored anyway...
If you're sure gdm3 is installed then try:
sudo systemctl disable phosh
Some extra/optional steps here and here.
so far so good.
But I still don't get a text/framebuffer bootscreen and permanent orientation is not possible either, despite I tried a lot with the options which are commented with "for pine Tab only"...
Login works and now I get my gnome desktop running in the 'correct' Aspect ratio, that is working fine so far.
(But... I think its too small anyway to use it as a desktop replacement.... will try out a HDMI Out Adapter, but then the whole concept is broken anyway:-)
Cheers
4920441
On Fedora using gdm, gnome 40 is running really good with screen rotatation, kernel 5.12, or back to phosh if needed...
  Latest firmware for PinePhone modem! Subsentient 106 217,598 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 209,629 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 504 11-17-2025, 07:49 AM
Last Post: danm1988
  How-To: Remote Control Your Phone from Desktop via VNC biketool 16 10,791 10-16-2025, 06:55 AM
  Movuan distribution for PinePhone merom 5 5,670 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,596 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Jami on the Pine phone ? bcnaz 8 14,240 06-09-2025, 04:17 PM
Last Post: j_s
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 60,372 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,820 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 67,686 07-26-2024, 10:35 PM
