xmpp&jabber client for Manjaro Plasma mobile
So - what is the best option to have up-to-date (MUC, MAM etc) jabber&xmpp chat in Plasma mobile?
  • Manjaro Phosh has Chatty. It supports message archive managment (MAM), message carbons etc and is good for private conversations. Drawbacks - no multi user chat (MUC) and it pulls in quite much Gnome packages as dependencies. As in Phosh it is used also as a SMS client, it could interfere with Plasma Spacebar app.
  • SailfishOS also integrates SMS app with xmpp one using telepathy-gabble. There is telepathy-gabble-plus update (http://devel.kondorgulasch.de/telepathy-gabble/) which extends it with MAM etc. Maybe a similar method could be possible to add xmpp to the Spacebar app? However - still no MUC
  • Gajim. Probably the best jabber client for Linux (with Dino). Sort of usable in Plasma mobile if the window sizes and other options are optimized in conf file. Roster and personal chats are scaled ok and keyboard integrates quite ok also. Needs double-tap to open chats in roster. MUC windows are not scaled correctly and keyboard hides the input field.
  • Dino. Probably the best jabber client for Linux (with Gajim). However, the current Dino for Manjaro&Plasma is the desktop one and although it starts and runs, it does not scale correctly and I was unable to input text as the keyboard did not pop up. However - there is a project to use libhandy for Dino to adapt it to mobile screens (https://github.com/dino/dino/issues/178) and the result is already promising (https://fosstodon.org/@linmob/105583488991640393). Any chance to get this branch into Manjaro&Plasma?
(03-24-2021, 02:07 AM)acrux Wrote: So - what is the best option to have up-to-date (MUC, MAM etc) jabber&xmpp chat in Plasma mobile?
Swift
(03-26-2021, 04:03 AM)Veraendert Wrote: Swift
Sorry, no message archive management in Swift Sad
Try out the Kaidan. it's working really nicely. However, for now, I don't use it since OMEMO is not implemented yet (wip)
https://www.kaidan.im/
(04-11-2021, 07:51 AM)p1trson Wrote: Try out the Kaidan. it's working really nicely. However, for now, I don't use it since OMEMO is not implemented yet (wip)
Kaidan seems to be in quite early stage of development. Even multi user chat (MUC) is not implemented so far. Neither is message archive management (MAM). Also Kaidan needs Qt 5.14, so the method to install ii is through Flatpak...
But good news is that Plasma Mobile Phonebook app now supports IM field including Jabber, eg. xmmp:username@server.org
then I guess you need to formulate your requirements, because everyone has different use-cases.
e.g - for me, the only showstopper for using Kaidan (IM) is the missing OMEMO implementation, I don't care about MUC
right now none of the xmpp clients usable on pinephone are supporting it(AFAIK). The other requirement (secondary) for me is to have audio/video calls support by the xmpp client (STUN/TURN). For me the ideal representation of such client is Conversations, so I still need to stick to AOSP running device.
So define your requirements, and you can quickly search on the internet on your own which one does fulfill your needs (currently probably none). If you're not a programmer, you can contribute by testing a reporting bugs and/or feature requests for any clients you want.
That I did in the top post - analyze the usability of available software.
Yes - Conversations is very good and I'm using it extensively with LineageOS&Nexus6.
Both Gajim and Dino support OMEMO, at least their desktop clients.
So Dino with libhandy would be an answer (at least for me). Unfortunately it is not yet packaged in Manjaro&PlasmaMobile.
I don't want to be a pain but .. usability != requirements Wink
OTOH, yes Dino looks promising, but as soon as Kaidan is mature enough, it will probably work better in plasma mobile just because it's part of the KDE family.
I use Gajim on my desktop, so I might give it a try on the PP
XMPP clients situation for PP is pretty sad, right now I use matrix/Jami as alternatives (where both E2E and audio/video calls work)
(04-13-2021, 01:33 PM)p1trson Wrote: ...as soon as Kaidan is mature enough, it will probably work better in plasma mobile just because it's part of the KDE family.
Good news is that Kaidan has got MAM in fresh version 0.8:
https://www.kaidan.im/2021/05/28/kaidan-0.8.0/
Hope we get it soon in Pinephone software repositories Smile
Preferably native, not flatpack... Wink
Kaidan 0.8 is now in unstable branch repositories.
If you are impatient, you can download the kaidan and qxmpp packages from there and install also to stable with pacman -U.
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 22,166 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,161 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,465 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 3,379 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,324 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,197 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,738 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,605 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 3,404 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 3,526 02-09-2023, 08:17 AM
