03-15-2021, 08:52 PM
(This post was last modified: 03-16-2021, 01:15 AM by dsimic.
Edit Reason: Wording improvements
While attempting to perform a performance comparison of A1-rated and non-A1-rated Micro SD cards, with additonal emphasis on using F2FS instead of ext4, I've encountered a major issue with the PineBook Pro's SD card interface. Here are more details.
In a few words, attempting to write about 14.5 GiB to a Kingston A1-rated 16 GB UHS-I Micro SD card (SDCS2/16GB) resulted in a failure and the following Linux kernel messages, after writing about 700 MiB to the card:
This happened two times in a row, which makes the issue very easily reproducible. Unfortunately, it also caused the Linux kernel to become locked up on shutdown, requiring the laptop to be forcedly powered off.
Here are the kernel messages upon inserting the A1-rated card:
For reference, here are also the kernel messaged upon inserting a 16 GB UHS-I Micro SD card that is not A1-rated (Kingston SDCS/16GB):
The card that is not A1-rated works perfectly. As perfectly as it can be expected from a Micro SD card, of course.
D'oh! My first thoughts were that I got a bad A1-rated card. Though, testing another A1-rated card (another sample of SDCS2/16GB) resulted in the same issue. Time to try another approach; I wrote the same 14.5 GiB to the first A1-rated card using an external multi-format USB 3.0 card reader (Kingston FCR-HS3), and the write operation completed without errors. Another write attempt, now using an el-cheapo, generic USB 2.0 Micro-SD-only card reader, resulted in no errors as well.
As a note, the write to the A1-rated card was about 30% slower (7.5 MB/s vs. 10.5 MB/s, as printed by dd) using the USB 2.0 card reader, compared with using the USB 3.0 card reader on the same upstream USB 3.0 port. That's curious, but I'd need to test with a better USB 2.0 card reader before drawing any conclusions.
So, there is some good and some bad news. The good news is that my A1-rated cards are fine (I was already prepared to blame Kingston!), and the bad news is that some problems exist in the Linux kernel driver for the Micro SD card interface in the PineBook Pro; it's pretty much safe to assume that the actual Micro SD card interface hardware is not the culprit.
I'm looking into the source of the Linux kernel driver, and I'll post my findings here. Things don't look great, there are more than a few "this hardcoded value should be safe for all SoC implementations" points in the driver. Though, those "safe" values could be tweaked and tested.
In the meantime, if anyone else has experienced the same or similar issues, please comment here.
[ 1933.684751] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1933.732717] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1933.895841] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1935.187343] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x1:(WRITE) flags 0x104000 phys_seg 256 prio class 0
[ 1935.187418] Buffer I/O error on dev mmcblk1, logical block 0, lost async page write
[ 1935.187464] Buffer I/O error on dev mmcblk1, logical block 1, lost async page write
[ 1935.187495] Buffer I/O error on dev mmcblk1, logical block 2, lost async page write
[ 1935.187527] Buffer I/O error on dev mmcblk1, logical block 3, lost async page write
[ 1935.187557] Buffer I/O error on dev mmcblk1, logical block 4, lost async page write
[ 1935.187585] Buffer I/O error on dev mmcblk1, logical block 5, lost async page write
[ 1935.187614] Buffer I/O error on dev mmcblk1, logical block 6, lost async page write
[ 1935.187642] Buffer I/O error on dev mmcblk1, logical block 7, lost async page write
[ 1935.187672] Buffer I/O error on dev mmcblk1, logical block 8, lost async page write
[ 1935.187702] Buffer I/O error on dev mmcblk1, logical block 9, lost async page write
[ 1935.204901] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1935.253334] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1935.675811] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1937.395704] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1937.656483] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1937.886460] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1937.887796] blk_update_request: I/O error, dev mmcblk1, sector 16384 op 0x1:(WRITE) flags 0x104000 phys_seg 256 prio class 0
[ 1938.316467] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1938.333230] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1938.381886] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1938.536382] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1938.542689] blk_update_request: I/O error, dev mmcblk1, sector 67584 op 0x1:(WRITE) flags 0x104000 phys_seg 256 prio class 0
[ 1777.728204] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1777.881900] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1778.177740] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 78
[ 1778.177828] mmc1: new ultra high speed SDR104 SDHC card at address 5048
[ 1778.179620] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[ 1778.189478] mmcblk1: p1
[ 56.649797] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 57.093248] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 97
[ 57.093339] mmc1: new ultra high speed SDR104 SDHC card at address 1234
[ 57.095057] mmcblk1: mmc1:1234 SA16G 14.5 GiB
[ 57.103859] mmcblk1: p1 p2
