Anbox apps listed in the launch screen
Is there a way to stop the apps that are installed in anbox from showing up in the app launcher screen? I've deleted the .desktop files from /home/mobian/.local/share/applications/anbox directory, but they are eventually recreated.
It's confusing to have 2 Settings apps.
Thanks.
Mark
(03-17-2021, 11:38 AM)mark1250 Wrote: Is there a way to stop the apps that are installed in anbox from showing up in the app launcher screen? I've deleted the .desktop files from /home/mobian/.local/share/applications/anbox directory, but they are eventually recreated.
Thanks.
Mark
you could use the purism anbox fork which has a patch to disable it, or just use their patch on the debian version. both involve recompiling anbox.
https://source.puri.sm/Librem5/debs/anbo...awer.patch
or if you want to trust a stranger on the internet, heres a deb or the debian version with that patch applied https://tvall43.ddns.net/stuffs/anbox_0...._arm64.deb
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 5,693 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 799 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 9,710 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,591 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,867 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,981 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 9,648 08-05-2024, 06:12 AM
Last Post: baptx
  Keyboard not popping up on QT apps 3x5co 1 3,058 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 2,210 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,350 06-24-2023, 01:55 PM
Last Post: freelectro
