Is it possible to get Pinephone electronic components separately?
I want to build a bicycle computer around a phone using the app "IP Bike", with a camera and a custom high powered LED on a rotatable mount, roughly perpendicular to the screen. The form factor / design would be almost entirely unlike a phone, but the phone's components are possibly better suited to this, compared to the available SBCs.
Is this likely to be possible? Either now or in the future?
You can buy almost any of the Pinephone parts in the store, but availability is scarce at the moment because of the general situation of the semiconductor market and making new batches of Pinephones takes up all the supply currently...
https://pine64.com/product-category/smar...46c16e2e66
I see! Thank you. I feel like I should've been able to find that on my own on the store page. Is it likely to be possible to use something like an ArduCAM with the Pinephone mainboard instead of the 5mpx camera listed there, and can I use a screen of my own choice?
While it's certainly possible to adapt other cameras and screens via breakout boards you have to make for the FFC cables to match the pinouts (there's no standard for this really), you also have to make sure all the signal voltage levels work with your new devices (e.g. 1.8V digital interface of the CSI bus, 2.8V analog supply, backlight driver current and voltage for the LCD, LCD MIPI interface, etc.), so it's not a trivial hardware hacking task. And then adapt the devicetree and kernel drivers to support your new devices. So it really comes down how familiar you are with embedded hardware and Linux kernel hacking?
Not familiar at all unfortunately. I've used Linux a bit, and done some other programming, but I'm mostly a CAD guy.
I've made a parallel thread in the A64-LTS sub-forum, because it's possible that meets my needs better; https://forum.pine64.org/showthread.php?tid=13341
I think getting the hardware connected would be the easier task for me, but I'll be in the deep end with the kernel and drivers. I'm guessing that I would be porting those over from a build that supports the hardware as a best case scenario right? Like taking a pi supported device, and the drivers for that and adapting that for Android on the Pineboard?
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,194 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,069 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,623 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,694 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,177 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,767 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,762 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,354 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,468 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,004 03-25-2025, 08:51 PM
