Warning, 5.5mm barrel-style power cables
I let someone look at my pinecil, they grabbed a standard 5.5mm 12v barrel-style power cable for the bench power supply assuming the pinecil used that standard and did the old push&twist to force it in.
After a few seconds of effort my associate had a stupid look on their face holding the connector cable but the center pin from the pinecil was jammed tight into the barrel connector.
Fortunately I was able to re-insert the pin and solder the broken power line back together, though certainly not as strong against a similar attack it works again over USB C (obviously) and the repaired barrel power port too so all is good.
(02-26-2021, 02:26 AM)biketool Wrote: I let someone look at my pinecil, they grabbed a standard 5.5mm 12v barrel-style power cable for the bench power supply assuming the pinecil used that standard and did the old push&twist to force it in.
Pinecil DC Jack is 5525 type which means 5.5OD 2.5mm ID, don't force jam the 5521 plug. The 2.5mm ID stick is too large for 2.1mm ID hole.
Read the Pinecil label, clearly stated 5525 type
That person breaks stuff, but IMHO worth posting the warning not as a complaint but as 5521 is common and plenty of stuff breakers out there will not read or understand the label.
Original planning is using 5521 socket instead of 5525. However, there is no 5521 type for such type of socket :-(
https://www.chipdip.ru/product/dc-005
This one?
This one?
This appears to be a 5521(5.5mm outside diameter X 2.1mm inside diameter) which is the wrong size though very common for 12v power.
There is a Warning in the Pinecil Wiki page also about DC Barrel and to use the Correct size 5.5mm, 2.5mm or DC5525.
https://wiki.pine64.org/wiki/Pinecil
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,483 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,691 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
Question Pinecil v2 power cycles at higher voltages? clemon79 3 5,234 08-10-2024, 05:47 AM
Last Post: RevAngel
  Connecting a power supply to the Pinecil jon_bondy 1 2,758 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 11,113 02-29-2024, 07:33 PM
Last Post: Okedokey
  Asus laptop power supply can also power Pinecil biketool 9 16,158 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  PD-EPR support and power rating over USB Joey_bikefast 1 3,091 11-05-2022, 01:32 PM
Last Post: River
  Warning: Don't try T12 tips csiwek 4 11,036 11-05-2022, 01:19 PM
Last Post: River
  Will this power supply work? 4.5mm -> 5.5mm conversion? TB12GOAT 0 2,648 02-19-2022, 08:06 AM
Last Post: TB12GOAT
  Pinecil Power Supply with Removable Cables Recommendations moriel5 1 4,178 02-08-2022, 09:50 PM
Last Post: moriel5
