slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
update:
kernel 5.10.3
update all packages Mon Dec 28 08:32:11 UTC 2020
slarm64-current-aarch64-base-rock64-5.10.3-build-20201228.img.zst
slarm64-current-aarch64-base-rock64-5.10.3-build-20201228.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.10.3-build-20201228.img.zst
slarm64-current-aarch64-xfce-rock64-5.10.3-build-20201228.img.zst.sha256
donation   irradium
kernel 5.10.10
slarm64-current-aarch64-base-rock64-5.10.10-build-20210126.img.zst
slarm64-current-aarch64-base-rock64-5.10.10-build-20210126.img.zst.sha256
slarm64-current-aarch64-enlightenment-rock64-5.10.10-build-20210126.img.zst
slarm64-current-aarch64-enlightenment-rock64-5.10.10-build-20210126.img.zst.sha256
donation   irradium
I am still using 4.4.246 kernel. However, 'slackpkg upgrade-all' is not working as before, it now returned with message of GPG key mismatch.
It's not working even after 'slackpkg upgrade gpg' command executed.
(01-28-2021, 06:20 PM)Enig123 Wrote: I am still using 4.4.246 kernel. However, 'slackpkg upgrade-all' is not working as before, it now returned with message of GPG key mismatch.
Due to a big update, not all packages have been redistributed, today they will be fixed, thanks for the information.
donation   irradium
kernel 5.10.10
slarm64-current-aarch64-base-rock64-4.4.254-build-20210130.img.zst
slarm64-current-aarch64-base-rock64-4.4.254-build-20210130.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-4.4.254-build-20210130.img.zst
slarm64-current-aarch64-xfce-rock64-4.4.254-build-20210130.img.zst.sha256
donation   irradium
Unfortunately the upgrade-all from previous version still fails.
And, what should do I do to upgrade to the new 4.4.254 kernel?
(02-02-2021, 04:21 PM)Enig123 Wrote: Unfortunately the upgrade-all from previous version still fails.
upgrade-all try changing the mirror, it appears first on slarm64.org
to update the kernel, you need to download the packages and upgrade via upgradepkg.
donation   irradium
Hi mara,
I have tried the latest 5.10.10 image, which causes endless reboot on my Rock64 v2.
The 4.4.254 kernel is okay, but after 'slackpkg update & slackpkg upgrade-all', there's errors during the upgrading process, it stuck with the following error messages:
Quote:+==============================================================================
| Upgrading sed-4.8-aarch64-2 package using ./sed-4.8-aarch64-3.txz
Pre-installing package sed-4.8-aarch64-3...
sed: /lib64/libc.so.6: version `GLIBC_2.33' not found (required by sed)
Removing package: packages
Any idea how to resolve it?
Edit1:
The second issue has been resolved by myself, after several failed attempts. To make it work, you'll have to download and install the latest
http://dl.slarm64.org/slackware/slarm64-...ch64-1.txz
http://dl.slarm64.org/slackware/slarm64-...ch64-3.txz
before 'slackpkg update & slackpkg upgrade-all'.
Edit2:
After upgrade-all, the issue of invalid pgp key is still there, whenever I intend to use slackpkg to install a package, it will always warn me about the pgp key:
Quote:You need the GPG key of slarm64 AArch64 <security@slarm64.org>.
To download and install that key, run:
# slackpkg update gpg
You can disable GPG checking too, but it is not a good idea.
To disable GPG, edit slackpkg.conf and change the value of the CHECKGPG
variable to off - you can see an example in the original slackpkg.conf.new
file distributed with slackpkg.
Edit3:
I just did another try, force using slackpkg to install every packages, it seems the issue described in Edit2 gone.
In summary, the correct way to upgrade from the latest image of 4.4.254 kernel is as follow:
1. 'slackpkg update'
2. 'slackpkg upgrade slackpkg' - upgrade slackpkg itself
3. 'slackpkg install aaa_glibc-solibs' - install missing package
4. 'slackpkg install aaa_libraries' - install missing package
5. 'slackpkg upgrade-all'
That's it.
(02-28-2021, 12:00 AM)Enig123 Wrote: In summary, the correct way to upgrade from the latest image of 4.4.254 kernel is as follow:
That's it.
yes, this is a bulk rebuild for glibc-2.33.
such an update is correct for any image (the kernel has nothing to do with it)
donation   irradium
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,192 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,085 11-03-2025, 09:25 AM
Last Post: darkfader
  Rock64 - not booting after Armbian update helpmerock 6 3,880 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,450 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,582 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,676 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 71,729 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 101,432 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,697 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,704 12-27-2023, 10:34 AM
Last Post: dstallmo
