Phonebook does not link with calls
Hi all,
Well, that's basically it. When I select a contact from the phonebook and click to call, it doesn't call, I think because the phonebook is not related to the calling application.
Someone else happens? How is it solved?
Thank you.
Make sure you include the country code with the stored phone number. That would be "+1" for the U.S. When bringing up a phonebook entry I'm finding a need to hit the phone button two or three times for it to work. (Remember this is alpha software!)
(02-07-2021, 01:49 PM)canaac Wrote: Hi all,
Thank you.
It is connected. There are a few issues though:
  • - Some applications (linphone-desktop, kde-connect) hijack the tel:// (or phone://) URIs as preferred applications, so they get invoked instead of the calls app.
  • - if you have not set the right region in your settings app, it might try to prefix the wrong international number
  • - there have been a few issues where the addressbook or calls try to "normalize" numbers, so a few combinations (depending on how you store your phone numbers) , might hit those cases.
That having said, I am not deeply involved with those apps, and have my knowledge glancing at the issue trackers.
Thank you both very much for answering.
I have finally uninstalled "kdeconnect" and it seems to be working fine.
  Calls 4G not working oliwierzgorniak 2 5,507 08-06-2024, 02:20 PM
Last Post: baptx
  No audio on calls after updating today Zebulon Walton 10 15,610 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  Backing up SMS and phonebook before wipe/reinstall biketool 2 4,199 05-09-2022, 09:20 PM
  Chrony interrupts calls. jhasler 0 2,216 04-18-2022, 08:48 PM
Last Post: jhasler
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,576 02-18-2022, 08:54 AM
Last Post: battlegarden
  Calls : two rings and call cut and restore. Gribouille 0 2,222 01-14-2022, 07:40 AM
Last Post: Gribouille
Question Best Way of Receiving Calls Without SIM (VOIP) lovepine88 16 26,427 10-07-2021, 12:38 AM
Last Post: AndyM
  *urgent help*calls and gnome-conatcs gone after update user641 24 36,716 09-20-2021, 12:19 PM
Last Post: calinb
  How does calls work in debian? temp0rary 4 8,574 05-31-2021, 10:44 AM
Last Post: temp0rary
  SIP for gnome calls cmicallef 1 4,336 04-26-2021, 06:30 AM
Last Post: vongillus
