SIP for gnome calls
https://source.puri.sm/Librem5/calls/-/m...quests/270
Checked out d0194fe53464f3bd97a14f8e32e3ab9a367a3985
Built as per README.md
Setup an account config as per merge request.
Incoming calls work.
Can dial from console (See https://source.puri.sm/Librem5/calls/-/m...ote_150323 for an example of dialing)
Can *Cannot*(edit) dial from UI or return calls from UI. However, this could be a VoIP provider issue as my VoIP provider does not use the standard ports (i.e. 5060).
EDIT (28 April 2021):
Made some changes to plugins/sip/calls-sip-origin.c to ensure that the sip: prefix, VoIP/SIP host and relevant port is included in any numbers submitted. Seems to be working well.
Also made some more changes regarding registration intervals given the requirements of my VoIP provider.
I will test for a good week before submitting the patch upstream.
That's cool! I am eager to test it once it gets into Mobian stable.
  New camera app gnome-snapshot working on trixie? vusra 4 5,106 04-11-2025, 02:53 AM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 5,687 08-06-2024, 02:20 PM
Last Post: baptx
  gnome-control-center: segmentation fault on startup jojuma 4 6,098 09-12-2023, 08:49 AM
Last Post: jojuma
  No audio on calls after updating today Zebulon Walton 10 15,865 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 12,031 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 2,161 05-27-2022, 11:43 AM
Last Post: jojuma
  Change GUI from Phost to Gnome (or anything else) johnpine 0 2,302 05-27-2022, 06:52 AM
Last Post: johnpine
  Chrony interrupts calls. jhasler 0 2,249 04-18-2022, 08:48 PM
Last Post: jhasler
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,664 02-18-2022, 08:54 AM
Last Post: battlegarden
  Gnome-podcasts on Debian repos user641 4 7,443 02-06-2022, 04:58 AM
Last Post: jsch
