New OS for RockPro64 is here, TwisterOS Armbian
#31
(01-03-2021, 02:33 PM)snoopy_ca Wrote:
(12-21-2020, 06:00 PM)jtremblant Wrote: Monka-Manjaro-XFCE beta1 is here:
https://drive.google.com/file/d/1I0yHIDf...sp=sharing
I just downloaded the image and it seems corrupt. Etcher complains before flashing (no valid partition table) and I cannot mount the flashed SD card. Can you provide the checksum or check, if the image on google drive is correct?
One question - Only the Manjaro build has Kodi installed, or? I tried the normal twisterOS from the website and didn't see Kodi in the taskbar.
Regards
Regards,
It's not corrupted, I stand 100% correct on the google drive file. You need to extract it first as I mentioned it on the instructions. The Reason why it's compressed is because is a large image file, weighting 9.4Gb uncompressed.
Armbian-Reforged V1.0 also has a Kodi built-in with full HW acceleration with OpenGL ES 3.0 Panfrost Mesa 21. If you need a built-in Kodi as shown on the screenshot below, I suggest you to try Armbian-Reforged V1.0 which is also smaller with a 5.2Gb image size only.
[Image: ARUHbS.jpg]
Introducing RockRiotMenu, a collection of pre-compiled apps and games for RK3399 and RK3326 Hardware.
List of Games included:
- Rick-Dangerous
- Doom 1
- Eduke32 (Duke Nukem 3d)
- OpenBOR
- Quake3
- CannonBall
- Flashback
- Cave-Story
- Shadow-Warrior
- Keen
- Quake2
- Diablo1 (GOSPA)
- Quake1
- Half-Like
- Doom2
- Wolfenstein-3D
Also, Moonlight-Embedded
Download it from here:
https://github.com/krishenriksen/RockRio...aster/misc
Many thanks @kreal from the TwisterOS Armbian team.
small temp monitor script for the pwm fan - For official ROCKPro64 10mm Low Profile Heatsink with Fan
[Image: dBgob1.jpg]
Download it here:
https://gofile.io/d/vRmm8q
Kodi is not in TwisterOSArmbianV1-0-beta2.img. I know you confirmed it.. Please triple check?
As noted previously, I did see Kodi in the manjaro version. Liking the debian version but lacking some of the promised apps (kodi for me mostly).
Great work though! I may switch to this soon!
(01-10-2021, 01:33 PM)mschoolbus Wrote: Kodi is not in TwisterOSArmbianV1-0-beta2.img.  I know you confirmed it..  Please triple check?
My apologies. Only Armbian-Reforged V1.0 and Manjaro-Twister-XFCE version have Kodi built-it
You may try Armbian-Reforged V1.0 version(debian based):
https://drive.google.com/file/d/1gQtgWz2...sp=sharing
Ok, It's a bit confusing as of yet, but I am sure you are ironing that out.
I just want all your games and goodies (kodi) on a Debian system for PBP.
Great work dude!  Thank you for the reply!
The Armbian reforged link you provided does include Kodi.. However, I can not get the keyboard working properly for the life of me.  I have an ANSI Pinebook Pro.  I did switch to the pinebookpro dtb file.
Hoping for a TwisterOSArmbianV1-0-beta3.img or RC with Kodi soon, matching the features of the manjaro version if possible.  I just can't use Manjaro or Arch because I don't hate myself.
A few games for your RockRiot thing:
openra, urban terror, eternal lands
A new TwisterOS Armbian beta3 update is about to be released soon. Stay tuned.
Update(01-22-2021): TwisterOS Armbian Beta 3 is finally here:
TwisterOS Armbian Beta 3:
- A Fully featured fast and lightweight OS for RK3399 SBC's that works out-of-the-box.
(Currently is better supported on RockPi4B, RockPi4C & RockPro64 boards)
- RK3399 boards w/4Gb RAM and a minimum of 16Gb microSD/eMMC is strongly recommended.
- Armbian focal 20.04.1 LTS aarch64 based
- 5.9.14 Kernel
- XFCE 4.16 DE, XFCE uses Xfwm4 VM
- Latest Panfrost w/ HW acceleration on desktop
- OpenGL 3.1 is also supported with fully updated Mesa 21.1.0
- Kodi and MPV built-in with HW acceleration support
- Docker Container support via Chromium browser for watching streaming services like
  Netflix, Amazon Prime, Disney+, Apple TV+, Hulu, Spotify.(requires to manually install a script)
- Theme switcher fully integrated into all themes in Theme Twister App. (Reboot after change required)
- Retro gaming emulators included like PPSSPP, DOSBOX-X, Mednaffe, Mesen, Mupen64Plus, PCSX ReARMed,
  Retroarch (Tested functional, but not included), Redream, ScummVM, and many more...
- BOX86 with latest updates included
- uSD and eMMC booting supported. (RK3399 - NanoPi-M4 requires re-seat of HDMI cable on power on due to firmware limitations, and supports MicroSD at this time)
- Several useful apps included on image such as: Steam, Lutris, Discord, My Android,
  Wine Desktop, USBImager, LibreOffice suite, Transmission, Gimp, MELD, VLC Player, Audacious, etc.
- 9 OpenGL games are also included for your enjoyment.
Known issues:
- Bluetooth audio is not working
- Kodi repository is missing and needs to be installed manually
  (sudo apt install kodi-repository-kodi)
- Docker Container requires to apply some extra steps to fix a no HDMI audio issue.
(Fixed via pavucontrol, and selecting proper output device)
General Instructions:
- Download RK3399 image from twisteros.com
- Prepare your storage media for flashing
- Flash image with Balena-Etcher or USBImager
- Edit /boot/armbianEnV.txt file and select correct DTB file that matches your RK3399 board
  (Default DTB is RK3399-RockPi4B) | Case sensitive! | Example: rockchip/rk3399-rock-pi-4c.dtb
- After first boot, resize EXT4 partition using Disks utility included
- Default password is: asdasd
- Overclocking and hardware profile support out-of-the-box.
Enjoy it.
[Image: KyYJeQ.jpg]
[Image: Y8b2Wy.jpg]
[Image: laNX2c.jpg]
[Image: 1NIiCU.jpg]
TwisterOS Armbian beta3 supports popular streaming services as Netflix, Amazon Prime Disney+, Spotify and others with chromium browser via Docker Container.
[Image: AH0zUG.jpg]
Just follow easy instructions from github webpage. Many thanks to Monka from twisterOS armbian team for this great docker container:
https://github.com/monkaBlyat/docker-chromium-armhf
Known issue: No HDMI audio on Docker Container with Chromium browser
To fix it:
- sudo apt install paprefs
- sudo ln -s /usr/lib/pulse-13.99.1 /usr/lib/pulse-13.99
- paprefs
- Reboot
Make sure after executing paprefs, all settings matches as shown below:
[Image: IyBJix.jpg]
[Image: bulwnZ.jpg]
- Reboot
- Enjoy
Updated (01-25-2021): First Official Release of TwisterOS Armbian V1.0
Download it from TwisterOS official webiste:
https://twisteros.com/twisterarmbian.html
[Image: OPSVNQ.jpg]
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 11 19,255 03-07-2026, 09:32 AM
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,592 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,263 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 8,987 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 39,210 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 120,833 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 3,903 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 3,568 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 5,793 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 4,427 01-03-2023, 06:53 PM
Last Post: raph
Users browsing this thread: 9 Guest(s)
