Full disk encryption is coming
Works like a charm on my 3Gb CE!
I like you, Mobian team... and you too, pmOS team.
(12-07-2020, 06:12 AM)a-wai Wrote: I only have BH and pmOS editions to test with, so it may flicker on UBports also (anyway, that's just the installer, it shouldn't affect the installed system)
Password entry is osk-sdl
Awesome, looks like there are a few significant usability improvements in the osk-sdl pipeline!
Did I got this right. Does this method also work for Ubuntu Touch? Can someone confirm that it is working for Ubuntu Touch?
If the screen is locked is the drive encrypted?  Or is the data only encrypted when completely shutdown?
(01-27-2021, 02:16 PM)brorean Wrote: If the screen is locked is the drive encrypted?  Or is the data only encrypted when completely shutdown?
I believe it is unencrypted at the point where you enter your passkey and is not encrypted again until the phone is shut down. That would be consistent with the way full disk encryption operates on other Debian-derived systems.
By the way I really like the new and improved virtual keyboard for unlocking the disk that came in pretty recently in an update. With popups confirming keystrokes and a locking CAPS key it has a better feel than the regular Mobian keyboard (albeit with a restricted set of keys).
Please be aware of this bug regarding the FDE-image 20201215
Updates of fresh FDE-Installation on SD-card alter eMMC
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 5,218 02-21-2025, 07:25 AM
Last Post: dragonhospital
  How to use an NVMe disk as rootfs Smaking 3 2,901 11-29-2024, 06:51 AM
Last Post: walter1950
  boot gets stuck shortly after disk decryption vortex 9 11,487 09-11-2024, 05:40 AM
Last Post: normangraves
  low disk space on file system root revisited benedikt55 2 4,156 09-24-2022, 10:16 AM
Last Post: benedikt55
  Low Disk Space on Filesystem root ichbins 9 11,426 08-28-2022, 10:52 AM
Last Post: Eugo
  Enter disk decryption passphrase error healthyliving101 3 6,289 09-07-2021, 12:21 PM
Last Post: Fenellakw
  Keyboard stopped working on disk encryption screen on Mobian after update cowsay 2 4,887 08-16-2021, 08:31 AM
  A clear all button for notifications is coming! ragreenburg 0 2,559 08-13-2021, 09:09 AM
Last Post: ragreenburg
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 17,596 03-05-2021, 02:33 AM
Last Post: Anna
  Is there an encryption package missing from mobian? rp3 0 2,947 01-27-2021, 05:16 AM
Last Post: rp3
