UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
#91
Thanks Megi. Right now I start to download it.  Wink
WOW, that's a great news!!! I'm going to download it right now!! Thanks!
Hello I made it to this step in the instructions
sudo echo ", +" | sfdisk -n -N 2 /dev/sdb2
sfdisk: cannot open /dev/sdb2: Permission denied
And when I try the next command I get
sudo echo ", +" | sfdisk -N 2 /dev/sdb2
Suggestions?
I can't get sound playback in UBports. I can get sound in Manjaro and Mobian once I change setting from Analog to speaker. Any idea as how to do the same in UBPorts?
(11-28-2020, 07:42 PM)K_Research Wrote: Hello I made it to this step in the instructions
Suggestions?
Where did that command come from? The elevated permissions from sudo only apply as far as the pipe '|' so sfdisk runs as the normal user, hence the permission denied. If you remove the first sudo, and insert one between the pipe and sfdisk, you'll probably get what was intended. As always when using sudo, make sure you know exactly what it's doing before running it!
UPDATE: It looks like you were trying to follow https://xnux.eu/log/#toc-resizing-the-pa...-the-image but using sudo, and changing the block device. I think you should be using /dev/sdb not /dev/sdb2 - the whole device not the second partition on that device.
(11-23-2020, 03:36 PM)megous Wrote: New version is now available. https://xnux.eu/p-boot-demo/
Thanks a lot! Smile
I followed the steps to resize the partition and noticed that the last two steps only work in reverse order, i.e.
df -h
only works before unmounting the partition.
Hey guys, I am trying to resize the partition to the max of the SDcard filesystem from the Pinephone, but for some reasons I can't find the command btrfs, I've tried with apt but it doesn't find the package. Which is really weird, because it should be a base command of Linux. I am probably missing something, any idea?
Pinephone Braveheart
Pinephone Manjaro CE 3/32Gb
Pinephone Mobian CE 3/32Gb
Pinephone Pro Explorer Edition
(11-30-2020, 07:14 PM)deedend Wrote: Hey guys, I am trying to resize the partition to the max of the SDcard filesystem from the Pinephone, but for some reasons I can't find the command btrfs, I've tried with apt but it doesn't find the package. Which is really weird, because it should be a base command of Linux. I am probably missing something, any idea?
Did you try searching for the correct package name?
apt-cache search btrfs
I think the one you want is btrfs-progs
(12-01-2020, 10:03 AM)wibble Wrote: Did you try searching for the correct package name?
Shame on me, I searched for btrfs-filesystem (I saw that in the 8 man page of the debian btrfs page, and I assumed that was it). Now I have managed to fix the issue, thanks!
(11-29-2020, 04:25 AM)neil_swann80 Wrote: I can't get sound playback in UBports.  I can get sound in Manjaro and Mobian once I change setting from Analog to speaker.  Any idea as how to do the same in UBPorts?
I tried porting the UCM profile in UBports to the latest kernel (without testing), but maybe it's somehow still not working. You can either debug the UCM profile, or wait until ubports moves from Linux 5.6 to Linux 5.10.
my website: https://xnux.eu
  PinePhone Game Thread PixelPaintbrush 31 80,996 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,791 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,192 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,293 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,061 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,351 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,893 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,464 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,033 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,362 10-06-2025, 09:05 PM
