braveheart / 3GB/32GB mainboard troubleshooting screen
hi
I just installed the new 3GB/32GB motherboard on my braveheart
I installed the new JumpDrive 0.6 image on an sd card.
I installed the version of mobian of 13/11/20.
I see the phosh menu then the screen is grey.
when I press the power button I can see the date and the device icons.
once the passwd entered, I have only the grey screen.
Tagging @a-wai as your tag is broken Smile
Problem resolved , it works after re-installed the small rubber part in the proximity sensor area.
(11-23-2020, 05:18 AM)chris_02 Wrote: Problem resolved , it works after re-installed the small rubber part in the proximity sensor area.
Have you taken the photo with a Pinephone?
no it's a screenshot of the martjin's vidéo
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 5,661 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 783 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 9,460 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,566 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,842 07-18-2025, 07:56 PM
  troubleshooting sleep/wake button on trixie biketool 5 4,049 05-04-2025, 08:11 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,976 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 9,631 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,205 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,348 06-24-2023, 01:55 PM
Last Post: freelectro
