slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#81
Will you keep updating 4.4.y kernel in the future?
As you mentioned that for now, 4.4.y kernel is maturer, at least in terms of video playback, compare with 5.8.y kernel right?
it is, but the developers are porting from 4.4.y to 4.19.y.
Yes so far 4.4.y is updated and supported.
Still, a lot has been done to play videos at 5.x, but so far I haven't really tried it.
donation   irradium
judging by the changes in the kernel repository, the rockchip team switched from the 4.4.y branch to 4.19.y, a test build:
kernel 4.19.153
slarm64-current-aarch64-base-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst
slarm64-current-aarch64-base-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst.md5
donation   irradium
update:
slarm64-current-aarch64-base-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst
slarm64-current-aarch64-base-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst.md5
donation   irradium
kernel 5.9.3
slarm64-current-aarch64-base-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst
slarm64-current-aarch64-base-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst.md5
donation   irradium
@mara,
While I tried for a while and failed to find the unzip package of slarm64, can you help me on how to install it? Or I will have to compile it from sources?
(11-22-2020, 12:30 AM)Enig123 Wrote: @mara,
here is the description by appointment README.TXT
zstdcat slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst > /dev/mmcblk0
donation   irradium
@mara,
I couldn't find logrotate tool with the image. Will you please give me some hint/reference where I can get start at?
(11-22-2020, 10:20 PM)Enig123 Wrote: @mara,
what image are you using base / xfce?
if you have slackpkg configured, run:
slackpkg install logrotate
if not configured, download the package and run logrotate-3.17.0-aarch64-1.txz and run:
installpkg logrotate-3.17.0-aarch64-1.txz
donation   irradium
Thank you for your quick help. BTW, I am using the base image, and the slackpkg installed from the current branch does not work as expected somehow. It kept asking for the correct pgp key.
Perhaps I installed the wrong version of slackpkg?
Edit: Another question is for how to unzip a .zip file, which usually use package named "unzip" in most Linux distributions.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,179 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 468 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,703 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,724 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,724 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,838 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,018 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 79,108 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 104,938 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,358 03-14-2024, 03:09 AM
