No HDMI signal from new Manjaro Community Edition phone dock
@sundog You obviously do not read enough in this forum.
So the question remains who is more trolling... Angel
(11-15-2020, 10:41 AM)LinAdmin2 Wrote:
(11-15-2020, 07:05 AM)wibble Wrote:
(11-13-2020, 09:28 AM)LinAdmin2 Wrote: Could somebody please explain this:
The same monitor using the same HDMI cable but branched to an ordinary X86 PC always worked. So I just wonder what makes the difference??
Different hardware, different driver, different platform and possibly different HDMI version. There's quite a lot of scope for little differences to cause a problem. I'd be more interested in the differences between the monitors that work and the ones that don't - that might help narrow down the possible cause(s). Are the HDMI versions different? Does it only happen with certain resolutions, refresh rates etc? Is there some EDID data quirk?
Of course there is very different hardware in all the monitors and most probable different versions of HDMI.
But with all the X86 systems and all the monitors I have used there was never ever the slightest problem with HDMI output. Therefore my conclusion is:
The PinePhone with the dock delivered has not been sufficiently tested before and we are the paying guinea pigs of pine64.org who once more does not at all care for customer satisfaction.
Sorry - I mistook your post for a serious query.
(11-11-2020, 12:19 AM)calinb Wrote:
(11-09-2020, 11:20 AM)brianary Wrote: It was fixed by the most recent update!
I've had my PinePhone for only three days and happily the update enabled an image on my HDMI monitor for the first time. However, the image is just wallpaper. How can I display something useful on it?
Hey I've just received my Manjaro Community edition a couple a few days ago, and I'm unable to get my external monitor to work via the supplied adapter/dongle.
What is this update?!!? I need to update, but am uncertain how.
Cheers
Cheers
Given the pace of software development, whatever they install at the factory will be out of date by the time you get the phone. It's really only there as a starter. See the wiki for a generalized install method, and for the list of OS options and links to their respective instructions, wikis, FAQs etc. I'd recommend Megous' multi-boot image on an SD card as an easy way to give most of them a try - they won't be quite the latest versions, and the kernel won't be quite as stock so there might be some minor behaviour differences, but it's an easy way to find out which ones you want to try installing properly.
https://wiki.pine64.org/wiki/PinePhone#O...ng_Systems
https://wiki.pine64.org/wiki/PinePhone_I...structions
https://wiki.pine64.org/wiki/PinePhone_Software_Release
  My Phone stopped making and recieving Calls tracyanne 0 10,547 09-14-2025, 03:30 PM
Last Post: tracyanne
  Phone powers off with high user demands car46999 7 8,489 04-11-2024, 09:17 AM
Last Post: zetabeta
  pinephone keyboard + dock question tuxcall 7 10,117 02-05-2024, 03:17 PM
Last Post: wigan
  Phone will not turn on (but sometimes will) insidetrip101 10 13,285 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 3,436 07-31-2023, 07:50 PM
  No calls on Pine Phone Beta convergence edition polypode 1 3,451 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  PinePhone keyboard layout with manjaro plasma daemonbsd 0 2,502 03-02-2023, 05:01 AM
Last Post: daemonbsd
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 3,667 02-20-2023, 12:14 AM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 43,175 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 40,677 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
