Mainline Debian Buster on RockPro64 ?
(04-24-2020, 03:39 PM)kuleszdl Wrote: Well, since Pine64 is focusing on the hardware someone from the community will have to step forward and do it.
That's a pity, because full Debian support would probably make the board more attractive to buyers. Seems like they're losing sales by not mainlining it.
Do you happen to know if recent mainline kernels get full performance from the PCIe bus? This would be important for the NAS use case.
I agree, I would love having official full support as well.
Regarding PCIe performance: Nope, you will very likely not get that on Debian mainline ever. The reason is that setting this is not safe by default because some boards seem to be faulty as discussed in this thread: https://forum.pine64.org/showthread.php?tid=8374
However, this is "just" a matter of the DTB file and not the kernel itself. Therefore, you just need to patch the dts, compile it to obtain the "speedy" DTB once and put it "hard-wired" in your Debian system. At least this is my plan and it seems to work fine so far.
There *IS* official support in Debian now (just in unstable)!
https://forum.pine64.org/showthread.php?tid=9744
(04-20-2020, 04:01 PM)kuleszdl Wrote: Update: I now have the following combo running:
  • Official Debian Buster
  • Official kernel from unstable
  • Self-compiled mainline u-boot (2020.03)
=> not a single, unofficial patch.
I'm about to try this myself. Which packages from unstable are you using?
Would you mind sharing your apt pinning config (presumably in /etc/apt/preferences.d)?
Did you use the debian installer and edit sources.list in the mounted /target filesystem, or did you do a manual debootstrap install, or something else?
In addition to the official image, the FreedomBox article may be of use.
@foresto
My approach is documented here: https://www.kulesz.me/post/140-debian-de...4-install/
(09-05-2020, 03:21 PM)kuleszdl Wrote: @foresto
Thank you very much for this @kuleszdl .
I'm trying to follow your guide, but I'm struggling a little with the partitioning of the virtual machine disk. I'm a little confused with the labelling. Are you using LVM on partition 3? If so, I assume that the volume group should be named "rootencrypted", and the logical volume "root"? Can you clarify this?
given the later instructions in your blog post, I assume you're not using LVM.
However, when creating partition #3 in qemu, I create a "physical volume for encryption" and name it "rootencrypted". I then choose "configure encrypted volumes" in the partitioning menu, and create a partition in this physical volume. The created partition is automatically named "vda3_crypt", not "root", and there is no way to change the name. Consequently, /etc/crypttab and /etc/fstab in the installed system also refers to vda3_crypt.
Is this irrelevant given that the later instructions will manually create the f2fs formatted partition with the correct name?
@n4tter4ngell Sorry for the late reply.
No, I am not using LVM as I try to keep the setup as simple as possible. I will try to record how I did the partitioning for you, hoping this will help.
"n4tter4ngell" - I updated my post and included a video with the detailed steps for partitioning.
Please don't be confused how the installer names the crypto device (sda3_crypt or vda3_crypt). That's just the name of the device, not the name of the partition label. Maybe this is what actually might have confused you? I added a hint, pointing this out more clearly (hopefully).
Once again, thank you for your feedback!
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,418 09-27-2026, 11:42 AM
  Freezes and kernel panics with Debian trixie jssfr 4 4,485 04-15-2026, 06:48 PM
Last Post: prahal
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 186,317 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,514 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,363 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,503 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 45,468 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 132,954 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 5,006 05-21-2023, 11:34 PM
Last Post: shpark
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,143 04-23-2023, 11:02 PM
Last Post: Thisone
Users browsing this thread: 15 Guest(s)
