VPN issue on Pine64
VPN issue on Pine64
I was trying to use OpenVPN client in the latest Android(04/28) build and the OpenVPN status shows as connected. However, I am not able to connect to the Internet with VPN 'ON' . I had the same issue with RemixOS. I am not sure if the VPN provider is blocking or is it something related to Pine64. Does anyone have this issue or is there away to find the root cause of this problem(probably a log or something).
Specifics:-
Pine 64 - 2GB
VPN provider - PIA VPN
OS - Android, 04/28/2016 image flashed using Phoenix card.
I had the same issue - but I was using PIA. As I upgraded to latest version of PIA - the prob solved automatically. My VPN was uploading tons of data even though I had nothing ON or any data in my box.
Yes. I tried the PIA VPN app and yes, it seems to work...Thanks for your response.
Bump. I cant get openvpn to work on android, android tv and remix os. I tried all three open vpn apps. It says connected, then after a while the connection drops and does not reconnect. On first connection it seems to upload a lot of data, but internet does not work.
Here is the openvpn log https://pastebin.ca/3800822
I dont have PIA, but I tried a free vpn with its own app from the app store with the same result
Same on Pinebook laptop. Any news?
  Pine64+ 1G and Pine LCD with Android 6.0.1 Tanveer 0 8,555 09-03-2018, 05:05 AM
Last Post: Tanveer
  2nd ethernet in PINE64 with android daniele 2 7,201 12-07-2017, 05:09 AM
Last Post: daniele
  Pine64 + Youtube TV Performance mikedice417 0 3,726 11-25-2017, 10:36 AM
Last Post: mikedice417
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,641 11-16-2017, 02:14 PM
Last Post: Skivholme
  Android 7.1 reboot on Pine64 2GB rkbren81@gmail.com 2 7,086 11-07-2017, 06:33 AM
Last Post: rkbren81@gmail.com
  Connecting external DVDRW drive via USB to Pine64 galbez 4 10,781 10-12-2017, 12:35 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,058 08-29-2017, 12:05 AM
  Boot hangs on pine64, how to debug? olh 1 5,923 08-29-2017, 12:04 AM
  Pine64+ 1G: boot loader details required Tanveer 4 11,494 07-29-2017, 09:07 PM
Last Post: Tanveer
  Android 6.0 for Pine64+ 1G and Pine LCD Tanveer 1 5,854 07-29-2017, 09:12 AM
Last Post: MarkHaysHarris777
