BAttery capacity
On the battery is written rated capacity 2800 mAh, typical 3000 mAh
See image in the wiki: https://en.wikipedia.org/wiki/PinePhone#...dition.jpg
I also saw this document from Pine64 wiki:
http://files.pine64.org/doc/datasheet/pi...cation.pdf
From the factory document:
rated 2800 mAh
type (?) 2820 mAh
So, I also read 'rated' means that comes from the factory description.  Not sure what is 'Typical' or 'Type' capacity.
What is a typical capacity? why is higher than the rated? who and how is measured? Why 'Type' and 'Typical' are different?
Just curiosity in case someone knows...
thanks
(10-19-2020, 11:12 AM)daniel Wrote: On the battery is written rated capacity 2800 mAh, typical 3000 mAh
rated 2800 mAh
type (?) 2820 mAh
thanks
The PinePhone battery build for 3000mAH capacity. However, factory cannot ensure that every battery is exactly 3000mAH due to manufacturing margin and 2800mAH is what they can guarantee.
rated 2800 mAh
type (?) 2820 mAh
thanks
I see... Thanks!
It look many OS has fixed the issues with the battery thanks to Megi
At the begining it was getting too hot, burning temps. Now is normal.
Also I think i read a 5000mAh is coming soon?
(10-21-2020, 08:29 AM)natasha Wrote: It look many OS has fixed the issues with the battery thanks to Megi
I think the monthly update said that it will be built in to the clamshell keyboard case.
Greetings, I am TG127 Smile
Owner of a Braveheart PinePhone and hopefully some other Pine products soon.
Yes, the 'second' battery in the keyboard casing was mentioned,
BUT, I believe I also read, a special rear cover was in the works to use a larger battery on just the Pine phone.
So many different options will be available for the Pine phone in the future.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
That'll be awesome if that will be the case. I guess all we can do is wait and see : P
  Battery connector dead mdk 5 3,890 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 2,969 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,816 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 11,073 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,020 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 12,177 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,512 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 49,100 02-26-2022, 02:07 AM
Last Post: vusra
  Battery replacement alternative sax1960 7 11,701 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 4,538 08-15-2021, 07:19 AM
Last Post: bcnaz
