Battery mot charging past 54%
I juste got the PinePhone but the battery does not seem to be charging past 54%.
I saw on the wiki that some OS' limit the maximum charging percentage in order to improve the longevity of the battery. Because I'm having this issue on different OS' it got me thinking that it is a hardware problem, but it might not be.
Is it a known issue ? What can I do about it ?
Many thanks !
I'm not aware of this being a known or already reported issue.  To aid in debugging, you could check the battery voltage when charged to 54%, which is available through /sys, and report back here.
cat /sys/class/power_supply/axp20x-battery/uevent cat /sys/class/power_supply/axp20x-usb/uevent
Actually, @8bit , those aren't the correct paths.  See below for the right ones:
/sys/class/power_supply/axp20x-battery/capacity /sys/class/power_supply/axp20x-battery/voltage_now
For example, battery voltage on my PinePhone was reported as 4015000, while the battery capacity was reported as 79.  After the reported capacity dropped to 77, the reported voltage dropped to 3999600.
Does the output of uevent not match the individual readings on your device?
cat /sys/class/power_supply/axp20x-battery/uevent POWER_SUPPLY_NAME=axp20x-battery POWER_SUPPLY_TYPE=Battery POWER_SUPPLY_PRESENT=1 POWER_SUPPLY_ONLINE=1 POWER_SUPPLY_STATUS=Charging POWER_SUPPLY_VOLTAGE_NOW=4224000 POWER_SUPPLY_CURRENT_NOW=205000 POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=1200000 POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=1200000 POWER_SUPPLY_HEALTH=Good POWER_SUPPLY_VOLTAGE_OCV=4203100 POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000 POWER_SUPPLY_VOLTAGE_MIN_DESIGN=3000000 POWER_SUPPLY_CAPACITY=89 cat /sys/class/power_supply/axp20x-battery/voltage_now 4224000 cat /sys/class/power_supply/axp20x-battery/capacity 89
Ah, you're right, @8bit, sorry...  I have a small shell script that pulls and displays a few parameters, and I run it using "watch -n 1", so I need the paths to the exact parameters for the script.  Thus, I somehow mentally disregarded the paths to the group/device parameters you've posted earlier.
(05-16-2021, 06:35 AM)dsimic Wrote: I'm not aware of this being a known or already reported issue.  To aid in debugging, you could check the battery voltage when charged to 54%, which is available through /sys, and report back here.
Thanks for the quick reply !
I left the phone charging for more than 24h and this issue seems to be gone. I don't know how to replicate it. But now when the phone reaches ~90% it starts discharging, although the cable is still plugged in.
I'm getting a bit confused about this...
The discharging is intentional; If I remember correctly, the charging rate slows down at 80% and stops completely at 90%.
(05-16-2021, 10:58 AM)StickyPine Wrote: I left the phone charging for more than 24h and this issue seems to be gone. I don't know how to replicate it. But now when the phone reaches ~90% it starts discharging, although the cable is still plugged in.
It's a bit strange that the battery initially didn't charge past 54%, but let's grudgingly accept that it got resolved spontaneously.  Maybe the battery needed some time to start accepting full charge, although it's still a bit strange.
Stopping the battery charging around 87-90% is the expected behavior, as it improves the longevity of the battery.  Also, that prevents the battery from overheating while charging, although there's very small possibility for the overheating in the first place.
(05-16-2021, 12:30 PM)dsimic Wrote: Also, that prevents the battery from overheating while charging, although there's very small possibility for the overheating in the first place.
Is there a way to change this behavior ?
  Battery life improvement freelectro 11 13,313 09-14-2026, 08:53 AM
Last Post: Juergen
  Battery connector dead mdk 5 5,499 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,023 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,456 02-17-2024, 04:15 PM
Last Post: vortex
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,650 03-20-2023, 12:54 AM
Last Post: bcoyle
  Charging Indicator On - Not Charging SJSEng 0 2,355 08-30-2022, 07:33 AM
Last Post: SJSEng
  Power supply vs battery albafrati 11 14,016 06-22-2022, 06:04 PM
Last Post: albafrati
  PPKB with phone; phone dies while charging SwordfishII 1 4,086 06-08-2022, 04:14 AM
Last Post: SwordfishII
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,902 04-28-2022, 12:45 PM
Last Post: james8880
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,433 03-08-2022, 12:25 PM
Last Post: jopple
