Can't get android to boot past initial startup screen
(05-02-2016, 05:32 AM)pinea64.edison Wrote: after this it is not going past the allwinner powered by Android screen. I even left it for over 1 hour but no luck....
Ethernet cord connected or not?
Ethernet is connected.
Sent from my Nexus 5 using Tapatalk
(05-02-2016, 05:34 AM)pinea64.edison Wrote: Ethernet is connected.
Well known issue N° 6: http://forum.pine64.org/showthread.php?tid=514
Funny that such an essential information is NOT LISTED at the download site where you got the OS images, isn't it? Writing something into this forum is like writing directly into a trash can.
TLLIM, can we not get this added to the blasted WIKI?!?!?!? Like right next to the D/L?
Ok. I will disconnect Ethernet on the first boot... But connecting HDMI to TV should not create a problem. Correct?
Correct
Correct
Thank you very much. Once I removed the Ethernet for the first boot, Android loaded perfectly.
I'm having the same issue. Using a power supply from a pi kit, a known good 8gb SanDisk sdhc card and an hdmi cable, I can't get past the initial boot screen. I'm using the latest android distribution burnt with phoenix. None of the previous versions have worked either. Using a windows 10 laptop with internal reader. Program won't work in compatibility mode, causes a runtime failure.
#19
(05-08-2016, 12:28 PM)b0neszero Wrote: I'm having the same issue. Using a power supply from a pi kit, a known good 8gb SanDisk sdhc card and an hdmi cable, I can't get past the initial boot screen. I'm using the latest android distribution burnt with phoenix. None of the previous versions have worked either. Using a windows 10 laptop with internal reader. Program won't work in compatibility mode, causes a runtime failure.
I just posted new Android DD image build for user who prefer not using PhoenixCard, please check out. For PhoenixCard user, please always to set "startup" on write mode option, and allow the build to have amper time when boot up due to the initialization process involve a lot of job and sometimes can stuck at home screen for 15 minutes.
#20
The 5/05 build fired right up. Love the new splash screen, very clean. Thank you!
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,721 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 580,794 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 47,555 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 30,305 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,958 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,323 10-10-2019, 07:57 AM
  screen rotating Miguelito71 0 4,956 07-29-2019, 12:48 AM
Last Post: Miguelito71
Question Android SDK Oreo NGC6691 2 9,908 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,309 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 391,677 03-12-2019, 04:53 PM
Last Post: neosapien
