slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64)
#31
update:
update: slarm64-current-aarch64-base-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst
slarm64-current-aarch64-base-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5
donation   irradium
update:
donation   irradium
update: slarm64-current-aarch64-base-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst
slarm64-current-aarch64-base-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst
slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5
donation   irradium
I can't get this image to boot. It keeps hanging at
## Flatened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
Installed on SD card with:
zstdcat slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst > /dev/sdb
Both images have the same result. Is there a boot parameter I need to change for this?
Thanks.
(10-20-2020, 01:51 AM)janv Wrote: I can't get this image to boot. It keeps hanging at
Thanks.
I have on this image, when I turned on, I left the audio card in usb3, then the bootloader was overloaded.
And the bootloader in spi is old or new from this release, try to erase the spi bootloader.
donation   irradium
That worked Smile I appreciate your work. Do you accept donations in Bitcoin?
Thanks, so far only patreon.
One of these days I will collect the image on the kernel 5.9.y.
donation   irradium
update: slarm64-current-aarch64-base-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst
slarm64-current-aarch64-base-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5
donation   irradium
update: slarm64-current-aarch64-base-rockpro64-4.4.249-build-20210107.img.zst
slarm64-current-aarch64-base-rockpro64-4.4.249-build-20210107.img.zst.sha256
slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst
slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst.sha256
donation   irradium
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 21,625 06-27-2026, 04:09 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 175,004 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,123 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 3,276 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 4,913 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,913 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 42,847 08-16-2023, 01:34 AM
Last Post: varac
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,549 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 7,294 05-13-2023, 12:01 AM
Last Post: swan
  Rockpro64 Dead on arrival? quixoticgeek 1 4,066 03-12-2023, 06:55 PM
Last Post: quixoticgeek
