My Daily QA - 2020-08-26
(08-27-2020, 12:10 PM)plainenough Wrote:
(08-27-2020, 11:49 AM)ragreenburg Wrote:
(08-26-2020, 01:11 PM)AmazingNutria Wrote: Be aware, these tests are being executed using an out-of-box testing methodology. All tests are preformed with minimal interaction/setup of devices outside of: OS imaging/updating,  SIM installation, Wifi Configuration,  and Power Cycling the devices.
Results: mobian/2020-08-26-Verizon.html
              mobian/2020-08-26-TMoblie.html
Conclusion: OS is not Ready for pinephone to be daily driver.
Notes: We starting test MMS messaging. Sadly we failed those tests today. Something i noticed, we started getting a ring back when calling out but only on Verizon. Speaker Phone took a turn for the worst in this build. UI just as responsive as last build.
Quick question, is it able to consistently hold service? My biggest issue with UT is it will say i have service when in reality I don't. So I'll be texting people and every once in a while text myself to see if my messages are even going through. So it seems like UT doesn't hold service for more than an hour or two.
This thread is geared toward Mobian. just FYI. But, I currently do not do any longevity tests on UT. (Ubuntu Touch aka UBPorts). I would bet that there are issues with keeping connected to your carrier for any extended amount of time.
Sorry, i should have been more clear. I understand that this is Mobian and am curious if that is a similar issue Mobian had. I can see now how I didnt make that clear.
That is a great question. I haven't ran any longevity tests yet. Ill keep that in mind going forward and will update you if i see anything worth mentioning on this topic
Thank you! That is the biggest thing for me is not knowing if I am actually connected or if the phone is just saying I am connected. If I can consitently text and use data/wifi then that is good enough to be my daily driver.
Getting back to MMS for a moment, this thread: https://forum.pine64.org/showthread.php?tid=11002 and the third post down suggests that because Mobian is reliant on Phosh, MMS isn't even available because it doesn't exist in Chatty or ModemManager yet. It may be worth noting it as an expected failure on subsequent QA tests until the two issues referenced in that thread are closed. There is still a lot of chatter regarding the issue which is exciting, it simply isn't ready yet.
By the way, @AmazingNutria is doing great work with these reports!
  2020-11-13 Image status. Gribouille 45 69,782 11-14-2021, 12:44 AM
Last Post: Gribouille
  Status update 2020-12-15 a-wai 33 66,651 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 12,559 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 40,434 12-31-2020, 09:51 AM
Last Post: HLing
  Status update 2020-11-15 a-wai 17 29,264 12-05-2020, 05:58 PM
Last Post: bcnaz
  Status update 2020-09-05 a-wai 26 50,496 10-12-2020, 01:50 PM
Last Post: dukla2000
  Status update 2020-10-05 a-wai 8 15,689 10-08-2020, 03:20 AM
  My Daily QA - 2020-09-22 AmazingNutria 4 9,171 09-25-2020, 08:33 AM
Last Post: bcnaz
  My Daily QA - 2020-09-11 AmazingNutria 2 6,002 09-20-2020, 09:17 PM
Last Post: daniel
  My Daily QA - 2020-09-10 AmazingNutria 1 5,138 09-11-2020, 08:30 AM
Last Post: daniel
