slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#71
Thank you guys, now I can access my Rock64.
Any chance that I can establish a compile environment on Slackware to build some service that I need?
(04-10-2020, 02:04 PM)Enig123 Wrote: Thank you guys, now I can access my Rock64.
No problem.
all necessary packages are in category D http://dl.fail.pp.ua/slackware/slarm64-c...slarm64/d/
use the package manager installpkg or slackpkg
update:
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
kernel 5.6.10
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
kernel 5.7.15
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
donation   irradium
(08-13-2020, 01:16 PM)mara Wrote: kernel 5.7.15
can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
update
the problem of outputting to the monitor was found out when using the converter HDMI-to-VGA on the 5.7 kernel
donation   irradium
kernel 5.8.3
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst.md5
donation   irradium
(08-20-2020, 09:48 AM)mara Wrote: can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
For different batch of Rock64 board version 2.0, the software/OS support can be quite different.
As I know, older version 2.0 has serious Ethernet issue with OpenBSD, while more recent batch is well supported. Hope this info helps.
thanks.
Thanks, both the old and the new kernel work on version 2.0 of my board (it's a pity there is no way to check for 3.0), in the old 4.4.y kernel video plays well up to 4K.
donation   irradium
  Xen hypervisor on Rock64 tumbleweed 6 9,835 11-03-2025, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,825 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,712 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,388 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,505 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,549 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 69,070 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 100,464 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,472 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,631 12-27-2023, 10:34 AM
Last Post: dstallmo
