Digitizer is on when screen is off
(06-11-2020, 05:46 AM)a-wai Wrote:
(06-11-2020, 03:36 AM)dukla2000 Wrote: There may be an artefact with the screen waking up unexpectedly, I need to check but with the phone running on battery, screen off, after 10 or 15 minutes it is all lighting up sometimes. This may have been some kind of notification about low battery power as my battery was sinking below 20%.
This is probably be due to a notification yes, based on my testing this is the only case where the display wakes up "by itself".
I am also having an issue with the phone waking up and the screen staying on for extended periods without any external input. There does not appear to be any notifications that I can find. It wakes up for about one minute then shuts off.
PinePhone UBports CE and Mobian on SD, Mint Mobile, Pinebook Pro Manjaro
(08-17-2020, 04:05 PM)klick Wrote: I am also having an issue with the phone waking up and the screen staying on for extended periods without any external input. There does not appear to be any notifications that I can find. It wakes up for about one minute then shuts off.
I also still have this - seems to be after the OS has been booted for a while. Often times a reboot seems to settle things. Which means (my amateurish debugging) there is some process that can get started after some use that keeps waking the screen for whatever reason.
For me, the battery seems to drain faster on Mobian than UBports UT. I assume the screen wake contributes to this issue. Since you are using it as a daily driver, how do you manage this? Regular charging or using a spare battery?
(08-19-2020, 10:56 AM)klick Wrote: For me, the battery seems to drain faster on Mobian than UBports UT. I assume the screen wake contributes to this issue.
Absolutely - as long as the screen is waking CRUST does not engage and battery consumption is (IIRC) around 10%/hour with the screen off, and even worse for those times the screen is on.
(08-19-2020, 10:56 AM)klick Wrote: Since you are using it as a daily driver, how do you manage this? Regular charging or using a spare battery?
I make/receive very few calls/SMS/messaging, so my phone spends most of the day in CRUST suspend mode Smile . I do a little browsing and check emails once or twice a day - most nights I am on around 30% charge left before I plug in.
(Yup, before CRUST I had a USB cable plugged into nearly every computer I sat at - the bad old days!)
As long as I do not touch the phone it does appear to sleep properly but once I toggle the screen or open it, then it starts waking quite frequently afterward. I am impressed with how far the whole Pine Phone project has progressed in a relatively short amount of time. Now I am just waiting on better camera functionality but more importantly, a better browser experience on Mobian. The Morph browser on UT works really well but sound quality is poor for watching videos and I cannot get Bluetooth or plug-in speakers to work on UT.
  How to add an homemade app to the main screen? JChdeL 3 502 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 1,952 07-18-2025, 07:56 PM
  On-Screen Keyboard Arrow Keys biketool 10 5,856 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,147 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,835 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 1,828 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 1,938 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 13,823 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 2,760 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 2,148 01-13-2023, 03:33 AM
Last Post: mdk
