what is the root password for debian?
i was able to run Debian Linux with Mate GUI 20160422 by lenny.raposo with Longsleep kernel (yaay) and login using following credentials
  • username: pine64user
  • password: password
    however, after issuing:
pine64user@debianpine64:~$ su root
Password:
it keeps asking me for password
any ideas?
Why do you want to be user root?
It's usually preferable to use the sudo command to elevate your permission.
its exactly how you said
pine64user@debianpine64:~$ sudo -l
User pine64user may run the following commands on debianpine64:
   (ALL : ALL) ALL
i was just curious, and there is no need to retype user password each time i use sudo command
anyway, if anyone want to change root password, just use sudo su, followed by passwd on root
Many recent linux distros disable root password login (and thereby su). Instead, root usage is restricted to a few users via sudo. This makes things a little more manageable, as there's is no single root password that all admins know, so you can remove root access for one user without forcing everyone to remember a new password.
Admittedly, this isn't an issue for single user systems, but it's probably something anyone planning on using linux across multiple systems in the long run to get used to.
The password is the same as the one for the pine64user account.
if you really need to be root...
as pine64user:
sudo su -
enter pine64user's password when prompted
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,012 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,336 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,465 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,735 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 165,170 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,355 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,704 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,957 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,032 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 670,293 05-21-2018, 06:30 AM
Last Post: Luke
