No idea what your Pine is doing? Serial console!
Information
Short, short form:
  • Connect the GND wire to Pin 6 or 9 of the EXP connector.
  • Connect the RX wire to Pin 7 of the EXP connector.
  • Connect the TX wire to Pin 8 of the EXP connector.
  • Connect to the COM port at 115,200 bps.
I used a CH340G USB to serial which I bought for talking to ESP-01 ESP8266 boards. You can use basically any USB to TTL Serial. I used PuTTY to talk to the serial, which Windows helpfully told me was COM13 when I connected it. Since my USB to serial has a female header, I used three male-to-female jumper wires to connect it to the EXP header. Pins 7, 8 and 9 are right next to the memory card slot. I used pin 9 as ground.
When I plugged in the power connector, I got to see the full boot process, including formatting of the memory card.
I got the information here: http://elinux.org/Pine64#Serial_Console
In the case of the latest (20160303) Android release, there is a root shell attached to this port. If you have no video, you can execute a safe shutdown here with "reboot -p". I have not tried Linux yet, but I would anticipate a normal login prompt there after boot.
(04-28-2016, 11:30 AM)hyperlogos Wrote: Short, short form:
The Linux build behaves same as Android build on console .
  pine store paulhide 1 4,967 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 7,996 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 11,581 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 9,875 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 12,723 09-19-2018, 10:30 AM
Last Post: mjgoode
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 7,453 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 9,363 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 13,426 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Using Pine cluster for Docker Swarm jpnh 1 5,301 11-22-2016, 07:11 AM
Last Post: jpnh
  Pine 64 IR Receiver not working rajatgarg21 1 4,710 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
