Major keyboard and touchpad fiemware issues
Hi there. I have finally received my Pinebook Pro recently, so i started playing around with it. However, i have encountered extremely frustrating bug with its keyboard and touchpad firmware: for some reason, from time to time it starts thinking that shift is pressed. Sometimes pressing right shift sets it back to normal behavior, but not for long. I am pretty sure it's not a physical defect: external keyboard acts in a similar way. I have tried to update my firmware with pinebook-pro-keyboard-updater, but that killed my touchpad. Any ideas how to fix that?
Which updater did you use? The one from ayufan's repo, or jackhumbert's?
(07-31-2020, 11:33 AM)tophneal Wrote: Which updater did you use? The one from ayufan's repo, or jackhumbert's?
I don't really know. The one that is being installed with pacman. How can i find out which one is installed?
Even if you plug a new keyboard, the pinebook pro keyboard is always here, working, possibly sending shift keycode.
The possibility of having a hardware defect on it is not vanished by pluging external keyboard.
You have to disable it first, via libinput.
But first, try this one : https://forum.pine64.org/showthread.php?tid=8884
Install Jack Humbert's firmware, 3 steps. Recover your trackpad.
strange things happening... after i left pinebook switched off for a while my touchpad went back operational. however, i have installed  jackhumbert's firmware update, but symptoms are same. shift is still lagging, and touchpad is dead again.
Okay, guys, it seems to be a hardware defect after all. All lags and phantom shift pressing stops right after i disabled its keyboard through xinput. I will write to support now. Thanks for your participation
  pinephone keyboard oliveira11670 1 2,395 05-20-2026, 09:19 AM
Last Post: zetabeta
  Yet another new Pinebook keyboard problem MikoBob 3 5,540 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro charging issues tomekdev 1 3,796 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 234,666 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 2,950 06-04-2023, 02:51 PM
Last Post: Besouro
  Touchpad Issues - August 2022 Run SteveCaruso 5 7,763 12-14-2022, 11:00 PM
Last Post: doug
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 9,023 06-19-2022, 09:47 AM
Last Post: Rosbeefandino
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 3,006 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 6,851 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 12,717 01-11-2022, 07:39 AM
Last Post: Valenoern
