battery store
on the store, the pine hone battery is still out of stock.
When will it be available with the pinehone Pmos edition pre-orders?
If not what equivalence on the market?
(07-05-2020, 09:20 AM)chris_02 Wrote: When will it be available with the pinehone Pmos edition pre-orders?
Extra batteriets are separate orders, you can not order them together with a phone.
Equivalent batteriets and all your other questions, are answered in the Wiki.
on the store, the pinephone battery is still out of stock.
When will it be possible to buy this battery on pin64 store?
I tested the battery compatible with the reference EB-BJ700BBC. It works perfectly.
you just have to plane the two small legs; this done, it fits perfectly in the phone; the back cover closes properly.
the link to order them:
https://www.amazon.fr/dp/B0144VB3BA
(07-15-2020, 05:12 AM)chris_02 Wrote: I tested the battery compatible with the reference EB-BJ700BBC. It works perfectly.
I can confirm this; I hacked off the legs and filed them down with a Swiss Army knife.
The battery is marginally taller than the included battery (by about 0.5mm?), though it can still be inserted and ejected with some effort. It sits flush and the back cover can be closed. The phone powers on and can be used without issue.
As an aside, if it were possible to 'laser off' the plastic which recesses the gold contacts, I imagine the replacement battery would fit in as smoothly as the included battery.
For posterity's sake, I purchased the battery from eBay UK: https://www.ebay.co.uk/itm/Samsung-J7-J7...3872553919
(07-17-2020, 07:56 AM)jed Wrote: As an aside, if it were possible to 'laser off' the plastic which recesses the gold contacts, I imagine the replacement battery would fit in as smoothly as the included battery.
No need for a laser, the plastic top is only a few mm, and can easily be taken off by pulling the label a bit down, so you can
get a knife under its lower edge to twist it up.
No guaranties for what happens though :-)
  Battery connector dead mdk 5 4,487 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 3,393 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,028 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 11,573 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,224 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 12,748 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,658 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 50,691 02-26-2022, 02:07 AM
Last Post: vusra
  Battery replacement alternative sax1960 7 12,091 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 4,685 08-15-2021, 07:19 AM
Last Post: bcnaz
